Question about Sony STR-DG800 Receiver
Im not getting sound coming out the right and left speakers.my system are sony STR_DG800 reciever and BOSE acostimass 10 speakers.why im not getting suround sound?
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Posted on Apr 07, 2012
SOURCE: Sony STR-DG810 w/ Bose Acoustimass 10
Try this:
Go into the menu settings by pressing "Receiver" --> "6-Video" --> "HDMI Audio" select "Amp," not "Amp+TV"
Yeah, it makes total sense to have a very important audio setting in the video menu.
Posted on Mar 11, 2008
SOURCE: STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Posted on Aug 02, 2008
SOURCE: Im going to be running a set of BOSE acoustimass
By set, do you mean just the satellite speakers? Without the sub? With the sub?
Your receiver front, center and rear channels are rated at 100watts per channel at 8 ohms. If the Bose speakers are 8 ohm speakers, you're good to go. And as long as they have speaker connectors on them, and are not specifically made to work with the sub, or with each other(in other words proprietary). If you are using the entire Bose system, it should work fine.
Hope this helps.
Posted on Apr 03, 2010
Apr 02, 2010 | Sony STR-DE675 Receiver
Sep 04, 2009 | Bose Acoustimass 10 Series IV Home...
May 12, 2009 | Sony STR-DG800 Receiver
Jan 10, 2009 | Bose Acoustimass 10 III System
Nov 08, 2008 | Sony STR-DG800 Receiver
Jul 06, 2008 | Sony STR-DG800 Receiver
Jul 01, 2008 | Bose Cinemate Digital Home Theater System...
Feb 11, 2008 | Sony STR-DG810
Feb 04, 2008 | Audio Players & Recorders
265 people viewed this question
