Question about HP Televison & Video
Finding the remote code for my universal remote
My remote code is not listed for the type of tv I have on the universal remote, I have a HP ID5220 and I would greatly appreciate if you knew the code or could point me in the direction of someone that knew. As of now I have to change the channel on the television manually and it's a pain. Thank you.
Posted by savestheday8 on
  • Jean DeLauche
    Jean DeLauche Jan 18, 2018
    Hello, Savestheday8 - Anyone answering your question will need to know the maker and model of your TV. Please add that information in the comment box.
5 Related Answers
Anonymous
SOURCE: Code for Direct TV remote control
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Best of luck
Posted on Dec 03, 2007
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Hitachi
Go to menu look under cable/air switch to cable if you have cable then look for Auto Programming press go this will then automatically program all channels that you reviced, a universal hand unit can not do the things that your hand unit can do ! If you need more help let me know.
Posted on Jan 18, 2008
Anonymous
SOURCE: AKAI Remote Code
I need the code for my universal remote for Akai PT5492
thank you
[email protected]
Posted on Apr 03, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: I have a philips tv
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 08, 2008
Anonymous
  • 8 Answers
SOURCE: rca rcr860 remote manual code list
http://157.254.235.130/public/RCR860.pdf
http://157.254.235.130/public/RCR860_code_list.pdf
These are the sites for the manual and Code List
Posted on May 29, 2008
APEX TV Model LE4643T - Purchased Silver GE Universal Remote. Tried all listed codes for APEX TV & UNIVERSAL but none have worked. Could you please help with finding a code to run my TV ?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
Nov 30, 2016 | GE Televison & Video
What is universal remote code for bd-2000 on rcrno4gr remote
Remote code for HP BD-2000 Blu-ray player - AT&T Community
https://forums.att.com/.../Remote.../Remote-code...BD-2000.../467...
AT&TDec 2, 2012 - I have an HP BD-2000 Blu-ray player that I recently lost the remotecontrol for. I do not see HP as a manufacturer on the DVD list when I try.
Universal Remote Control Codes List - TV SAT DVR ...
removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Nov 10, 2013 - We compiled this universal remote programming code list to make it ..... Looking for a code for a orion vcr I have a 5 digit universal remote by rca -rcrn04gr and I ... remote control code (s) for a samsung blu ray dvd player bd-fm51 /ZA ... Please, could someone to give me the code for DENON AVR-X2000.
Programming the RCA RCRN04GR Universal Remote
voxrightnow.custhelp.com/.../programming-the-rca-rcrn04gr-universal-r...
Jul 28, 2010 - Program your Remote. To use this universal remote with your home entertainment system, first you need to program it to control your devices.
[PDF]Rcrn04gr - Universal Remote Control Codes
Jan 19, 2016 | HP bd-2000 blu-ray player with 1080p...
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
What is the code for an hp television?
0465 0189 0601. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 05, 2014 | RCA Universal Remote Control
I am looking for the VCR Codes for a Hitachi VCR on your remote. Could you please give me the code to program my VCR?
The One-For-All code list gives:
standalone Hitachi VCR: 0000 0042 0041
Hitachi TV/VCR combination unit: 0000
See the following page for the full code list: http://oneforall-na.com/remote.php?type=URC4220 and look for the codes link near the bottom of the page.
If your device was built within 6 months before the remote was programmed or is newer than the universal remote, the codes may not work. If this remote allows, try scanning through all the codes. However, if it still doesn't work, you need a newer universal remote, a universal remote that can be programmed from a computer or an exact or substitute replacement remote for the device. Search remotes.com for a replacement remote - use the model and not the manufacturer for the best chance of finding the remote.
I hope this helps.
Sep 18, 2010 | One For All URC4220 Remote Control
Having difficulty with a code for a vizio tv.
go to the following website and look at the manual. i do not see vizio listed as one of the brands, but there is a section on how to retrieve a remote code that may not be listed.
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
good luck
Dec 07, 2009 | Big Button TV Universal Remote
Trying tp program remote need codes
Hello
Below I have a link to a website that lists the remote codes for nearly all universal remotes. Scroll down to the type of remote you have, select the model number, then scroll to the type of tv you have(HP). This site is not 100% all inclusive but it is very comprehensive. If you have trouble finding the code, or if it is not on this site, please post back with the type of remote (make/model) and I will be glad to help you find it.
In the future, please include more info in the original post to allow us to help you easier.
Remote Codes:
http://www.xdiv.com/remotes/
Hope this helps and please don't forget to rate.
-Chris
May 07, 2009 | Televison & Video
Comcast universal remote codes don't work for zenith zhd-311 dvd/receiver/home theater
Had the hardest time finding a code for this old TV.
Posting now so that others can find this solution.
White-Westinghouse
Modle: WTV-11901
Comcast Remote Control Code 0451
Dec 22, 2007 | Zenith ZEN310 Universal Remote Control
Televison & Video Logo
63 people viewed this question
Top HP Televison & Video Experts
Davit Mamyan
Davit Mamyan
Ellen Tumey
Ellen Tumey
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
