Peddle starts and stops with little foot pressure or just stops. also sews very slowly then stops or runs jerkily. or does not work at all.
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
SOURCE: My Husqvarna Prism 990 only sews in reverse.
You could have an electronic problem on the main printed circuit board or in the feed length stepper motor. You may also just have a bound section in the feed mechanism. I don't think there is a cure all answer for this problem.
A 1/2 second hesitation between depressing the foot control and motor response is very common in these machines
If your husband lubricated the bushings on the upper and lower shafts of your 990 I recommend that you have him remove all of the lubricant possible and keep your fingers crossed. The 990 is a self-lubricating machine and applying machine oil to these bushing will probably cause them to seize. The 990 should never be lubricated in many of the places you would lubricate many machines. Hopefully, you haven't done irreparable damage.
SOURCE: start/stop button problem will the machine run on its own
You have to unplug the power cord to the the foot pedal. The manual doesn't include this. And good stinkin luck with Sears or Kenmore customer service! Just pull the cord out of the machine and the start/stop button will work. Try it on a slower setting at first though. Also, if you need additional presser feet, Singer, Brother, Janome, and possibly other brands will usually work as long as they are the snap on type. I really do like my machine, good luck with yours!
SOURCE: My Viking 5710 starts to sew without any pressure on foot pedal
Mine does the exact same thing. I think the problem might lie in the cord to the foot pedal. The cord packs into the foot pedal for storage, which forces the cord to to remain bent during storage. I believe the wires in mind became damaged and broken so I took it apart and reconnected the wires at the spot where the connector meets with the wires. But I still don't leave it plugged in if I'm not using it, it could be a fire hazard.
