I need to reset my tascam da-88 to its factory settings
SOURCE: how do u reset a dell computer back to factory setting?
if your computer shows a blue bar at the top of the screen and says www.dell.com you can try ctrl+f11 which will start the system restore sequence......hopefully you have one of the dells which containt this feature
SOURCE: need to reset to factory setting
Press reset button on back of unit AFTER system has fully booted (time will be displayed) and your system will be back to default values - password = applianceadmin.
You can also re-image the drive to factory defaults.
AnOldMan
SOURCE: code to reset factory settings for zte a201
CAN I PLEASE GET MY PASSWORD TO RESTORE MY FACTORY SETTINGS OF THE ZTE A201.
SOURCE: i need to reset my tascame to its origanal factory
You will lose all your data. Here are the instructions:
Turn off your unit, push down on the following buttons; Quick Routing, Shift, Sendand Shut Down button. Keep all these buttons down at the same time and keep them down while you turn on the power button to boot up the unit. You will see the changes being made as the unit boots up. Good Luck!
