Hi. I just bought a brand new Toshiba 32' LCD TV. I was playing with the remote control to try and change the picture size (which I eventually did), but I somehow screwed up the sound.
The sound is now scratchy and fuzzy. The TV picture is fine.
Can anyone help me undo whatever I did? Is there some "revert to factory settings" command?
Is there a quick fix for todhibs grey screen or fog?
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
On your remote control click menue and than select sound and go from there
SOURCE: Flickering tv screen when playing playstation games.
I don't think it's a configuration problem at all. I do think that the set is not adjusting to the correct format. Most Stores have 30 day return policy. If it's over 30 days then they may not take it back. If you bought it online, then, the return may be difficult. If the return is not possible, then, contact Toshiba online and find a local Toshiba authorized servicer in your area. Hope this helps.
SOURCE: TV does not respond to Remote
Dear Mr.yeye,
There seems to be a problem with the IR LED of your television. solder the connections if any of them is cut. Also there can be loose connections. its better to contact the retailer from whom you purchased this tv
SOURCE: Toshiba Color Television....now picture is black and white
Good day.
The missing color issue can be resolved by resoldering the loose contacts in your units circuitry. Your unit is still worth to be fixed.
Response is highly appreciated.
chris
SOURCE: tv remote for 32 inch toshiba flat screen tv
tohhiba codes 062,064,085,229,231,385. for cable tv converters use 019.
