Has anyone else had the problem where when you switch on the storio the screen is blank and will not then switch off or do anything?
SOURCE: Brand new storio wont turn
First you need to check some basic things, like try to change the batteries and open the card reinsert it.
If still the problem exists, then the cause could be the internal board and for that the device not able to get the power.
SOURCE: Ik krijg een zwart beeld met touchscreen
Even bellen met de klantenservice van VTech (www.vtechnl.com) dan krijg je een SD-kaart toegestuurd en met die kaart kun je de Storio resetten en updaten. Het heeft namelijk te maken, werd mij verteld, met een update die ik niet heb uitgevoerd. Daarna zou het niet meer voor mogen komen.
SOURCE: my son's vtech storio's touch
my sons v tech storio wont turn on and im using rechargble battries can some please help
SOURCE: Vtech storio not switching on when new batteries
Only had product for two days.when turn it on
a blue screen appears and nothing happens.cant turn it off
The blue screen seems to happen when you change the batteries (it's what happened to us). The blue screen indicates that there's a software problem, like when you boot up your computer and for some reason it freezes up. That software needs to be reinstalled. You'll lose anything that was saved on the v.reader, but at least you'll get it working again.
vtech could have made it a very simple problem to solve just by adding in their customer support: Blue Screen? follow these steps. But they don't, so here's how:
You'll need an SD card with at least 64mo of free space. If you want to use the one from your digital camera, transfert all of your pictures to the computer. Everything on the SD card will be erased.
Download the Recovery software from either link below (you can find both on the vtech website)
For the US version
http://contentcdn.vtechda.com/vtechkidsDownload/US/VReader/Tool/Recover/US-engRecoverCardTool.exe
For the Canadian english version
http://contentcdn.vtechda.com/vtechkidsDownload/CA-eng/VReader/Tool/Recover/CA-engRecoverCardTool.exe
This is the link the the website page itself: http://www.vtechkids.com/download/ca/en
Run the program and follow the instructions (at least those are clear and easy to follow). Mine worked fine after that.
Hope that solves your problem.
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up,
please perform the below procedure to restore the Storio back to factory
standard - please note this procedure requires the use of a blank SD memory
card and some form of SD card reader (either a port on the PC or a USB SD
reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or
via a USB SD card reader - this should appear as a removable disk under your
computer menu
•Double click the
Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover
Program Card' then click 'Next'
•From the drop down
menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes,
the actual drive allocated to your SD card may differ)
•The application will
now format the SD card with the Storio factory default operating system
•When the following
screen appears, remove the SD card and then re insert it into the SD port or
reader to complete the format
•Once the format is
complete the following confirmation will appear - please click OK and follow
steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once
the process is complete, you will need to re run the program to 'revert' the SD
card back to a usable state
The blue screen seems to happen when you change the batteries (it's what happened to us). The blue screen indicates that there's a software problem, like when you boot up your computer and for some reason it freezes up. That software needs to be reinstalled. You'll lose anything that was saved on the Storio, but at least you'll get it working again.
You'll need an SD card with at least 64mo of free space. If you want to use the one from your camera, transfert all of your pictures to the computer. Everything on the SD card will be erased.
Download the Recovery software from either link below (you can find both on the vtech website, but it took me a while to get there)
For the US version
This is the link to the website itself: http://www.vtechkids.com/download/ca/en
Run the program and follow the instructions (at least those are clear and easy to follow). Mine worked fine after that. And since there's no reset button on the Storio, this is the only way to erase the 100+ drawings that your child saved.
Hope that helps
