Question about Dishwashers
Bosch dishwasher overflows thru front door
BOSCH dISHWASHER OVERFLOWS, but drainsok when door is open and strainer is removed.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Is there an opening on the right hand side of the inside of the machine?I had this happen and it turned out it was because this hole (opening) needs to be clear during operation. Try running it with nothing on the right hand side and if it doesn't overflow, that's the problem. You can only put short stuff in the back bottom rack on that side.
Posted on Apr 06, 2012
5 Suggested Answers
Anonymous
  • 130 Answers
SOURCE: BOSCH DISHWASHER RUNNING TOO LONG PROBLEM
Bosch dishwashers are designed to heat the water to temp. However it has a 3 hr default if it doesn't reach temp. Start the cycle and see if after 1 hour if the water is hot or cold. If hot, then it is heating the water and the water coming in is just too cold. You may try running the water at the sink to get it hot there first before starting the dw. If the water is cold, then your unit isn't heating the water. At this point I pull the outer door panel, find the largest wires on the control unit and put my meter leads on them then start the machine. You will see 120 volts on your meter. Start the machine in light washes and with in 10 to 15 minutes you should see 0 voltage. Than means the relay has closed in the control and the hot line of the 120 volts is being sent to the heater. If this never happens, then you have a bad control. Bosch dishwashers have a 5 yr part warranty on the electronic control. Now If you get the 0 volts, I will put my amp meter on one of the same wires and check for 9 to 11amps. If that isn't there, then you have a bad heater assy. Hope this helps
Posted on Jan 06, 2008
odiebugs
odiebugs
  • 949 Answers
SOURCE: bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Posted on Apr 09, 2009
Anonymous
SOURCE: Bosch Classic xx dishwasher; not
slimline classic xx bosh dishwasher not pumping out water??
Posted on Jan 17, 2010
Obertelli
Obertelli
  • 3006 Answers
SOURCE: I have a Bosch SHE 4AM12UC dishwasher. My problem
There is either food debris blocking the action of the dispenser lid, or the solenoid which releases the door is sometimes failing to operate. The latter fault can be due to either a faulty solenoid or a loose/damaged cable connection anywhere between the main board and the solenoid: bear in mind that every time the door opens and closes there's a flexible connector which gradually fatigues and there are electrical connections which can be loosened if the door is regularly allowed to slam shut.
Your machine is still in current production, so it may still be under the manufacturer's warranty. if so, then repairs will be free provided the fault is not due to a failure to follow the operating instructions.
It's not really a DIY fix unless you are a competent and experienced home appliance repairer, but you can check for any food debris around the dispenser lid. If in any doubt run the machine empty using dishwasher cleaner. The possible electrical faults I've mentioned aren't necessarily expensive in terms of parts, but the labour will typically be about one hour.
An alternative is to use the new detergent dispenser from Finish. This sits in your machine, preloaded with twelve doses of detergent which are automatically released with every wash. It's an expensive way to buy dishwasher detergent, but it's a quick and relatively cheap fix which may buy you time until you can afford a proper repair.
If you do think that you may be able to diagnose and repair the fault on a DIY basis then I highly recommend the Haynes Dishwasher Repair Manual which you can either buy or perhaps borrow from a public library.
I'm hope that you have found my reply to be of use, all that I ask in return is that you take a moment to rate my answer.
Posted on Mar 02, 2010
Testimonial: "Excellent detailed response and very quickly given!"
Bosch dishwasher overflowing
Check the float. The float is a mushroom shaped item on the bottom of the DW. Gently Check to see that it moves freely.
Next:
Dec 16, 2013 | Dishwashers
How do I tighten the door handle on my Bosch dishwasher model SHY56A 05UC/14?
Remove front panel then you can access the handle screws. Open the door and remove the 'torx' screws surrounding the perimeter of the door.
Oct 06, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Where do I find the pcb on a Bosch dishwasher classic xx?
Check at front door top. You may have to open the screws around the door.
May 21, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch dishwasher not completing its cycle
Sounds to me like you have a problem with with the overflow switch or float. To access the switch or float you must pull d/w out and remove the left side panel(as you face the d/w).
Mar 29, 2010 | Bosch Dishwashers
Our Bosch Dishwasher Not Draining After Normal Washing Cycle
make sure the filter is not blocked by anything like a straw or just junk
Apr 02, 2009 | Bosch Dishwashers
Bosch dishwasher SHU4326uc/u12 is leaking from the door. How to change low door sealer?
I have had the same problem and finally stumbled upon the answer today!
If you are looking inside your dishwasher, look mid way up the right side wall and there is a valve/hole...if that hole is covered up (e.g. cutting board, ect) it will cause water leakage.
Weird huh? But that recommendation is coming straight from the Bosch headquarters in Canada. I would not have believed it otherwise, but I have read this solution twice, and now myself, have not had a leak since I stopped placing things over that hole! My model is SHU3326UC.
Feb 27, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Detergent latch install for Bosch SHU3307UC dishwasher
you need to remove the front panel of the dishwasher. you need to open the door and remove the 6 torx screws on the inside of the door, close the door and lift up and out to remove front panel. you wiil see the detergent assembly there
Jun 25, 2008 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Dishes are not clean due to insufficient water. Arms are clean, strainer is clean, water supply is OK,some soap is still in opened dispenser
Disassembled solenoid, found plugged inline strainer (caused by water shut-down in building to replace recirc. pump) Pulled and flushed filter basket, problem solved. Solenoid must be removed to access filter which is in sol. body. I hope this can help anyone who does'nt have a tech manual or flow diagram.
Mar 29, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
403 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
