Question about Motorola Mag One BPR40 Two Way Radio
Motorola BPR40 beeps constantly
It just beeps constantly, any ideas what can it be?
1 Related Answer
eradiostore
eradiostore
  • 1658 Answers
SOURCE: re: MagOne by Motorola, BPR40
None of the buttons will solve this issue.
A repeating low tone is heard when you press the PTT if your battery level is low. You may have a bad or poorly charged battery. It takes more energy to transmit than to receive, so the first place this shows up is when pressing the PTT. A quick way to check this is to swap batteries with a known good radio and see if the problem switches to the other radio.
Battery tips: Clean your battery contacts with a pencil eraser to remove the film caused by hand oil. Always charge your battery with the radio turned off. And be certain your charger is plugged into an outlet that is not connected to a light switch shutting off power. Batteries last approx. 2 years. Check your battery's date code to see its age. (3 or 4 digit number, first one-two numbers are the year, second two are the week of the year. example: 1132 would be 2011 the 32nd week)
If the above does not solve your problem, you should see your local Motorola dealer, or a nationwide repair center for more assistance. Current flat rate repair on this style unit is typically around $69.
FYI: Your buttons are likely top button = monitor/sticky monitor and the bottom button could be hi/low power, scan or one of several other features. Each button has a short and a long press option.
Best regards.
Posted on Aug 09, 2011
F&p E331T constant beep
The ActiveSmart system that manages the fridge will beep when there is fault, and the amount of beeps will indicate the fault code.
To understand the fault code, a technician would also need to know the version of activesmart, and the product ID on the grey label on the bottom right of the fridge.
Dec 02, 2016 | Refrigerators
How do I get my microwave to quit beeping?
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 11, 2015 | Microwave Ovens
I have a quanta 3082 MB in a HP Pavilion zd8230us laptop when I startup it beeps constantly got any ideas? anyone
The beeps with have a pattern to them. Listen closely when you first turn the laptop on and listen for the pattern. It might be something like 1-3-2 (1 beep, wait, 3 beeps in a row, wait, 2 beeps) It will repeat for listen for a bit to make sure you have the correct pattern. Once you have that pattern got to the HP webpage, in the support section, in the search type in "beep code errors". It will give you a list of beep patterns and tell you what the problem is. It could be the RAM, it could be another problem with the motherboard; those codes are what you need to have first.
Dec 24, 2014 | HP Computers & Internet
Constant beep beep beeb from Maytag
forum.appliancepartspros.com/oven...ranges-cooktops/5209-maytag-ove...
https://www.maytag.com/product-help
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
On power up just get contant beeping won't boot
constant beeping sound is usually a key on the keyboard that is stuck. If it is not constant, like long,short,long beeps, that may indicate a problem. Let me know it is is constant or a beep code.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 23, 2010 | Acer Aspire 5315 Notebook
My PC wont start up, all it does is beep constantly. I don't have any idea what to do. Please can you help?
Beeping when the computer first starts up indicates a hardware failure. It can be bad memory, bad motherboard or something else is bad.
You can look up the beep codes from your computer manufacturer's website under support or Google It.
If you are not able to replace memory or motherboard on your computer, You will need to have a computer tech look at your computer.
Sep 30, 2010 | Computers & Internet
My eTrex Legend cx beeps constantly when turning off. The only solution I have found is to remove a battery. Any ideas?
I have the same problem. The unit is only 1 week old and I have used it maybe 5 times. The problem started a couple of days ago when I removed the USB connection from my Mac without ejecting it first. I think this might have screwed up the microSD card. I noticed that if I remove the microSD card the unit turns on and off normally. but is I have the microSD inserted, it turns on oK, works (apparnetly) Ok, but freezes with a constant beep when I turn it off.
Will try to reformat the card (any idea how to do that on the unit itself?)
Aug 18, 2009 | Garmin eTrex Legend Cx GPS Receiver
Beeping will not stop and coffee maker will not operate
The constant beeping means something is out of place. Take out all removable parts and put them back in their proper place (and close the lid when you are done) - should stop beeping after that.
Mar 22, 2009 | Cuisinart Thermal DGB-600 Grinder
Motorola Mag One BPR40 Two Way Radio Logo
814 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
