Our freezer is freezing everything but the fridge is warm and nothing is getting cold. We have the thermostat set at the coldest but still you can feel no airflow but you can hear the fan. HELP!
Is the fan on in the freezer?? if not then you need a new evap fan..also check to see if there is frost build up on the back panel in the freezer section if so then you have a defrost issue could be a bad heater..to bandaid the problem..defrost the freezer back panel so air can flow into fridge side, but you will need to address the problem within a week or it will build up again
SOURCE: freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
SOURCE: Our beko frost free fridge
the thermostat in the fridge is turning off your compressor before the freezer has completed its job.this is because it doesnt care about the freezer temperature only the temperature where its located in this case the fridge,try completely defrosting the fridge and restarting it
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
SOURCE: GE Side by Side freezer cold but not freezing, fridge is warm
you might have a defrost problem, timer,heater or bimetal when the coils freez up they dont cool enough .
SOURCE: freezer works fine, fridge cool not cold.
if the freezer is freezing and the fan working in the freezer and the fan at the compressor is working and you have no frost build up on the back wall of the freezer caused from a defrost problem -then turn your controls back to the middle. one of the controls is a thermostat control and the other control is merely an air diverter from the freezer to the refrigerator. if you close this diverter down too much (by putting it on 9)it will leave most of the air in the freezer.
bottom line if the freezer is working properly and freezing good all the time then the refrigerator should be ok as well unless you have diverted most air to the freezer. allow 24 hours after you have changed the settings.
you can feel air blowing in the back of the refrigerator at the top next to the freezer and can adjust the diverter control and feel the difference it makes. most of the time the control you use is labeled freezer and if you put both controls on 9 then your freezer will be the coldest but the refrigerator won't get as much air. the thermostat control can be left at 5 or higher (this is the control that turns the refrigerator off) but leave the other control at 5
if this doesn't work you have probably got problems with your freezer also and may not know it yet.
