ACPI\MTC0003\4&3656B0&0 I Get This when I do a search for Problem Devices on my RECOVERED laptop. I believe it is for my card reader. Could you please give me a link to a safe place to retrieve the driver please. Thanks
Posted by Frank Darling on
  • Frank Darling
    Frank Darling Apr 06, 2012
    My computer model EasyNote E3248SEW is not listed in Packard Bell's list of Models.. How do I find out what version my laptop is Thanks.. & Thanks to Tony Tahlman For Reply
  • tony wahlman
    tony wahlman Apr 06, 2012
    Sorry, I'm was so inconclusive.....goto this page:
    ftp://ftp.download.packardbell.com/NOTEBOOK/EasyNote%20E3%20series/Driver/Xp/
    directly on right hand side on Download / Support side there is a text:
    Link to the old page
tony wahlman
    Master:
  • 796 Answers
Download driver on manufactures website
Posted on Apr 05, 2012
5 Related Answers
Rommel Balcita
  • 749 Answers
SOURCE: digital camera sd card stuck in laptop
Hi...
Remember that the SD card has a little slot at the center we'll use that to retrieve the card. First, find a "medium safety pin" and straightened it and on the sharp edge, use a plier to make a little hook... Use that to pull it out....
Use an extended card holder to insert the SD card because the design is for the mini stick SD card...
Goodluck... happy Fixya...
Posted on Feb 06, 2008
Anonymous
SOURCE: wipro wivnb7710 Laptop driver download
Sir Please give me link for download wipro wivnb7710 Laptop Driver
Posted on Apr 30, 2009
sheila skaggs
  • 383 Answers
SOURCE: notebook onboard memory card drivers
Issues relating to msgrv32 Second, verify that your sound card has the latest drivers and/or updates installed from the computer or motherboard manufacturer (if onboard sound).
Computer Video Card Support and Help Drivers, Video card drivers and manufacturer listing. ... CH000193, Issues with adding new video card to computer that has on-board video.
Good Luck, Please dont for get to Vote,Thank You.
Posted on Dec 26, 2007
mitch_3020
mitch_3020
  • 70 Answers
SOURCE: Device Drivers
Hi axcel07,
So you just did a reinstall of Windows XP on a Dell Inspiron 8600 laptop. You can actually download the drivers for you laptop at this location: http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_P4M_8600&os=WW1&osl=en&catid=&impid=
Now about the items listed:
1.) Multimedia Audio Controller = SIGMATEL STAC 9750 AC97
2.) Network Controller = Broadcom 440x 10/100 Integrated Controller (wired)
3.) PCI Modem = check out the list since there is a lot of items listed
4.) Video Controller (VGA Compatible) = check out the list since there is a lot of items listed
One way to find out the correct driver is by checking the details of your computer at this link: https://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?~ck=ln&~tab=2&c=us&l=en&lnki=0&s=gen just enter your service tag.
Otherwise, please contact Dell Technical Support so that they can give you the information you need and they can even guide you in reinstalling the drivers.
Hope this helps!
Peace! :)
Posted on Oct 20, 2008
Teet Bergmann
  • 565 Answers
SOURCE: card reader driver
http://www-307.ibm.com/pc/support/site.wss/license.do?filename=mobiles/60cr03ww.exe
if helped rate fixya
Posted on Jan 05, 2009
Base system devices tanda seru
Base system devices normally refer to the card reader. Follow the link to download the card reader driver:
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=16
Mar 17, 2012 | Acer Aspire 4530-5889 Notebook PC
Tip
How to recover photos from memory card or hard drive
If you have accidentally deleted your photos from your camera or phones digital memory card or even your ipod or the HDD on your computer, there is still a reasonable chance of recovering them.
A full recovery is not guaranteed, but depending on the type of format that was used and particularly if it was a simple deletion of photographs it is quite often the case that photos can be recovered if the correct steps are taken.
First off - do not take any more photographs using the memory card in question.
The reason is, that should you overwrite the card with new photographs, some of the previous photograph information will be damaged and this will hamper the recovery operation.
If the photos have been lost from your memory card, you will need to have a card reader on your computer. If you have not got one of these, you can purchase a cheap multi-card usb reader that will do the job from the likes of Amazon or any hardware/computer store.
See this example.
Next, you will need to download and install a photo recovery program to your computer. There are several of these available to download for free from the net but for this purpose I am going to stick to one called Recuva which I have found to be easy to use and extremely comprehensive in its options. Recuva comes from a highly respected software company called Piriform and can confidently be recommended as free from Spyware, Adware or Viruses.
Best of all it is totally free to use and has no nags. You can download Recuva for free from this link.
Recuva is compatible with Windows 7, Vista, XP, 2003 and 2000. Including both 32-bit and 64-bit versions.
You may choose to search for an alternative recovery program on the Net if your operating system is not supported.
Download the program from the link provided above and then run the install wizard by clicking on the downloaded file. Follow the instructions to install the program on your computer. This program bundles Yahoo Tool Bar so please ensure to uncheck this option if you do not want this add on.
Insert your card into the card reader on your computer.
One distinct advantage to this program, is that it runs a wizard when you open it which walks you through the recovery process. Follow the instructions on the wizard and select the look for photographs option. Next select the "On my media card or Ipod option" to have it examine your card with the deleted photos.
If you want to scan your computers hard drive for deleted photos select that option instead.
Important: Click 'Enable Deep Scan' to have the best possible result from the scan. The program will automatically scan for recoverable files on the memory card in your card reader or hard drive as selected.
Be aware that this program is extremely thorough - and depending on the size of your card or drive, it may take some time to complete. Be patient as it completes its task. The program will then display the recovered photographs and give a comment beside each one to say if it has been damaged or is recoverable. Save the recovered photos onto a new file on your computer.
Once you have recovered and saved your photos - make sure to use your camera or device to format your memory card before using it again to capture photos.
A format will erase all data permanently from the card including corrupted data and so reduce the potential for future corruption of the card. This will help to avoid problems of this nature occuring again.
Thanks for reading this Tip and I do hope it has helped. If so, please do take a moment to register your vote for this Tip using the Yes/No buttons below.
on Jan 22, 2010 | Cameras
Tip
If you have accidentally deleted your photos from your cameras digital memory...
If you have accidentally deleted your photos from your cameras digital memory card or even the HDD on your computer there is still a resonable chance of recovering them.
A full recovery is not guaranteed, but depending on the type of formatting used or whether it was a simple deletion of photographs it is quite often the case that photos can be recovered if the correct steps are taken.
The reason is, that should you overwrite the card with other photographs, some of the previous photograph information will be damaged and this will hamper the recovery operation.
If the photos have been lost from your memory card, you will need to have a card reader on your computer. If you have not got one of these you can purchase a cheap multi-card usb reader that will do the job from the likes of Amazon or any hardware/computer store.
See this example.
Next you will need to download and install a photo recovery program to your computer. There are several of these available to download for free from the net but for this purpose I am going to stick to one called Recuva which I have found to be the easy to use and extremely comprehensive in its options. Recuva comes from a highly respected software company called Piriform and can confidently be recommended as free from Spyware, Adware or Viruses.
Be aware that this program is extremely thorough - and depending on the size of your card or drive it may take some time to complete. Be patient as it completes its task. The program will display the recovered photographs and give a comment beside each one to say if it has been damaged or is recoverable. Save the recovered photos onto a new file on your computer.
Finally - once you have recovered and saved your photos - make sure to use your camera to format your card before using it again to capture photos.
This will erase all data permanently from the card including corrupted data and so reduce the potential for future corruption of the card. This will help to avoid problems of this nature occuring again.
Thanks for reading this Tip and I do hope it has helped. Please do register your vote for this Tip using the Yes/No buttons below.
on Jan 22, 2010 | Baby Care
I have a 2009 acer laptop with windows 7. Well, I was on my laptop and I put it in sleep for a while so I could get ready for bed. So about an hour later, I went back on and apparently while on sleep the...
What you should do is download the driver of the graphic card. In Dell's Laptops you can find a number called Service tag which will help you to download the latest drivers. Go to the link below and click on how to find my service tag and from there on you will be able to download the latest drivers for your pc which I believe might solve the problem.
Also be careful where you leave the laptop, you should be aware that laptops might overheat and because of that they can crash creating problems like the ones you saw.
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
Hope this helps,
kind regards,
DL
Feb 28, 2011 | Acer LXA3706003 Notebook
I accidentally deleted the photos on my camera. Is there a mechanism to retrieve deleted files on the camera. Please help?
I have had success with this... Download this photo recovery program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Aug 03, 2010 | Samsung NV10 Digital Camera
I have an Acer 9300WSMI laptop. Does it have a card reader and if so where is it? Thanks Fitzy
SD card slot is on the right hand side of the laptop (with it facing towards you) at the front.
SD card slot is #2
Regards.
Jul 28, 2009 | Acer Computers & Internet
Toshiba A105-S4284 laptop card reader not working with vista
You will have to download Vista drivers for these devices.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1467727&rpn=PSAA8U&modelFilter=A105-S4284&selCategory=3&selFamily=1073768663&selModel=1467727%7CPSAA8U#
Once at the site, select downloads tab, and refine your search by Windows XP.
Good luck mate, and feel free to rate this advice.
Mar 15, 2009 | Toshiba Satellite A105-S4284 Notebook
No audio device after reformatting
Try to check the model numberfor your laptop,then go to goole search then go to Acer driver downlord using the model number it will give you the drivers u want for your computer.Let me know the results please.
[email protected]
Mr CPU.............
Apr 06, 2008 | Acer TravelMate 2300 Notebook
Card reader drivers
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
go to this page and at here you can give your model no
then search for drivers
if it shows then good 4 u
if not then search for live chate support from hop on left side pannel
login with proper details and hp live chat session helper will give you link of exac t drivers for your card reader
but please see model no on backside (downside of laptop with serial no and other stuffs thats the corerect one )
the one which is written on your screen is series no
so we need exact model no
if you can not find then let me know i'll chat on behalf of you and solve your problem
but confirm modelno on downside of laptop once again otherwise we might got wrong drivers
Mar 29, 2008 | HP Pavilion dv6000z Notebook
Modem and media card not recognized on HP Presario V2000, AMD, XP Prof, Vers. 2002 SP2
alll the drivers can be downlaoded from the compaqs site . u need to enter the seril number of machine . if that devices are shown in device manger with an yellow qn mark .then that devices will work if proper drivers are laoded . give me ur computer serial no . i will send the link to that files
Jan 29, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
2,261 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
