Question about Texas Instruments TI-30XA Calculator
How do i put a number to the 80 power on ti-30xa calculator
There is not a carat button ^ or x to y or y to x button that i can find.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
The y^x button is located along the right edge of the keyboard, just above the divide key.
Posted on Apr 05, 2012
5 Related Answers
Anonymous
  • 43 Answers
SOURCE: TI-30XA
Use the inverse log key sequences "2nd LN" or "2nd LOG" depending on whether you are using natural logs or logs to base 10
Posted on Dec 31, 2008
Anonymous
SOURCE: cant get M2 off of my TI-30XA calculator
Remove the six screws on the back cover. After the batteries are installed you need to reset the board. There is a little reset area that needs to be shorted to get the calculator back to normal. Look closely at the circuit board- You'll see a little circle next to the word reset. Its near the middle of the board. Wet your finger- press it on the circle. It should short. Blow it dry with your breath. It should work...
Posted on Aug 26, 2009
k24674
  • 8092 Answers
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
Posted on Sep 17, 2009
k24674
  • 8092 Answers
SOURCE: how do I reset the calculator after installing new
[OFF] ON/C] clears display, errors, all pending operations, constant calculations K, and STAT, but not M1, M2,and M3. Sets DEG angle units, floating-decimal format.
To clear memory M1 : Store 0 in 1
0 [STO] 1 clears M1
0[STO] 2 clears m2
0 [STO] 3 clears M2
Posted on Feb 03, 2010
  • 102366 Answers
SOURCE: Can you calculate nCr ?
Yes. Use the 2nd [nCr] function.
52 2nd [nCr] 5 = will calculate the number of 5-card poker hands that can be dealt from a deck of 52 cards.
Posted on Apr 06, 2010
1.009 to the 17 power and higher
The TI-30Xa has a "y^x" key located just above the divide key. To calculate 1.009 to the 17th power, press 1 . 0 0 9 y^x 1 7 =
Okay so i am using a TI-30XA What is the button on this calculator for (Prb) ??
There is no probability key on the 30Xa as there is on the 30XIIS. The shifted functions of the 8 and 9 keys will calculate the number of combinations and permutations, respectively. The shifted function of the 3 key will calculate the factorial. There is no random number generator.
5helpful
2answers
I need to raise e to a power on my TI 30XA Can you help? Thanks! [email protected]
Put in the number, press 2nd [e^x], then =
[e^x] is the shifted function of the LN key on the top row of the keyboard.
2helpful
I have a TI -30XA calculator. Need a battery for it. What is the number of the battery? Thanks, Ed
The TI-30Xa uses two A-76 lithium batteries. Comparable battery model numbers include: Duracell® D357 and Eveready® 357
4helpful
Does the TI-30XA have a sign to raise the number to a power of 4 or 5?
There's a key marked y^x (y-superscript-x) to raise a number to any power.
How do i type in a number like 22 to the 23 power times 18 to the 23 power
in the calculator put in 22, then press the YX key located above the divided sign. then hit enter. after that it the times button and put in 18 then the YX button and then 23. hit enter and there should be the solution.
17helpful
3answers
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
1helpful
The e to the x button
If you mean (e to the power x) minus 4, where x = -1, the key sequence would be:
+/- (above 3 key)
2nd
LN
Result is -3.63212.....
If you mean e to the power (x-4) where x = -1 again, it's:
10.0067379....
+/- (above 3 key)
2nd
LN
Answer
Ti-30xa
Display has gone....you will have to buy a new calculator, fortunately the TI-30XA is only $10-$15!!
Texas Instruments TI-30XA Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Ekse
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
