Hie, I have not been using my O2 XDA II mini for more than a year. Now when I have intended to use it and put it on charge the external battery is showing 100% but the back up battery is showing as "NONE".Also the phone is not recognising the SIM card and when checked the IMEI of the device is also not available on the device screen- Is the back up battery causing all the above said problems?Thanx for your kind help Pritam
SOURCE: Battery problem
My O2 Xda Atom Life mobile theme can't be used .
Whenever I applied my mobile theme , the screen background just turn blank or without any picture or colour on it , what i can see on the screen is just the mobile items . What have happened to my pda phone ?
SOURCE: O2 XDA II Mini *.Cab Fine Not working
it seems the .cab files you are installing on your phone...they are not ment for your PDA's OS....plz use the sutable cab files for WIndows Mobile 2003
all the best
SOURCE: o2 atom battery won't charge
I would suggest you to buy a new battery, since the one you have is 2 years old. If that doesnot solve the problem, you could try checking the mini connector on the phone. Sometimes, due to heavy usage (connect and reconnect to the jack) it is damage/loose. Try bring them to a repair shop.
Prob. 1)The back up battery is showing as "NONE". 2)The device is not detecting the phone (IMEI no. is also not displaying) but the device and the PDA is On. What could be the possible cause(s) for the problem and the solution to it.
Thanks
