Question about Yamaha Electrical Supplies
How many output ohms generator xt 89 benetton
Yamaha generator xt ohms
1 Related Answer
tabbycat282
tabbycat282
  • 56 Answers
SOURCE: I need to know what is the generator output (in
Your generator/alternator has an output of 37 Watts @ 8,000 rpm ( 12v x 3.1 amps = 37.2 watts) all the best....BLASTUS
Posted on Dec 07, 2009
How to test your stator on a xt 125 yamaha
use an OHM meter
you should get a mac of 274 ohms
Jun 12, 2010 | 2003 Yamaha YZ 125
Wire from generator not on plug
Hi and welcome to FixYa,
Per you need of "...wire diagram for generator area...", please see below. Should you be interested, the full wiring diagram for a Yamaha XT600E maybe viewed here.
Good luck and thank you for asking FixYa. Happy Holidays.
Dec 25, 2009 | 1991 Yamaha XT 600 E
I need to know what is the generator output (in watts) of a 1998 yamaha xt 350.
Dec 07, 2009 | 1998 Yamaha XT 600 E
Onan Marquis Indiana 5000 generator
You MAY have blown the rotating diodes on the rotor.
This would require servicing.
Sep 05, 2009 | Yamaha 4500 Watt Electric Start Generator...
No voltage engine ok
might need to excite the generator with a drill.
Apr 30, 2009 | Yamaha 2300 Watt Generator - EF2600
I can not find maintenance manual for YAMAHA XT 600 E
Google " service manuals yamaha "
or go to www.repairmanuals.com
or try your local library. Often guys will donate manuals to the library.
You can get a free pdf service manual on this site;
http://www.carlsalter.com/motorcycle-manuals.asp
Please rate this solution.
( four diamonds would be nice ), Thanks wdns331m!
Apr 06, 2009 | 1990 Yamaha XT 600 E
No spark
remove the ignition coil from the bike.
The primary winding should have a resistance between 2 and 6 ohms
The secondary winding should have a resistance between 19Kohm and 40Kohm.
In fact the primary must have less than a 50ohm, but there MUST be a resistance.
The secondary should have a resistance of 15.000Ohms and more, but there MUST be a continuity.
Mar 28, 2009 | 2002 Yamaha XT 600 E
Electrical Supplies Logo
41 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Dan Horsefield
Dan Horsefield
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
