SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
SOURCE: Ricoh Aficio SP 420dn shows SC542 error code after
Hi dear pls take you printer to service center
Thank you
Imran
Pls rank as possible have nice day
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
SOURCE: how i reset error sc 546 on ricoh aficio 4100n
Turn the machine off, hold down online & escape, turn machine on and wait for "1.Service Menu"
Select service menu, find sp 5-810, select #/enter, when it says "execute select #/enter, then escape. Turn machine off then on.
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
