check and test battery --cdi---connections kill switch and safety switches this is service manual it will assist in troubleshooting problem -------https://www.manualslib.com/manual/1183991/Suzuki-Gsf-400-Bandit.html-
No. The gs500 has rotor on right side. 600s have two rotors. The following website will let you compare part numbers. http://www.suzukipartshouse.net/pages/parts/viewbybrand/parts.aspx
Real easy, just drain oil, take off side case and remove the bolts. Take it off as an assembly. Make sure clutch plates and friction plates are positioned correctly.
Are you sure you need to replace the clutch? I assume it merely needs a minor adjustment.
