Question about Pool & Spa
Lay z spa 6cf problem
When i plug in my pump error 6cf appears it is pluged in to an indoor socket directly any idea whats wrong
  • Mmierz2009 Aug 22, 2019
    6cf is actually no connection to ground manual page 8. Check your plug and socket, replace extension lead.
Mmierz2009
    Welcome Back:
    Visited the website for 2 consecutive days.
Checked pump- works, checked heater- works, checked blower- works, flow switch- work, temperature sensors both 56Ohm at 22degrees 6cf is shown when plugged in. If hold buttons and switch the power I can get the blower and water working for split second and 6cf Cuts off relays. I did not found any water detector/preventing the unit working dry ? Does it have one?? Pump, blower, and heater doesn't have any feedback To the pcb it works through relays, I think something else is throwing 6cf.
Anything else I have missed?
Posted on Aug 21, 2019
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: layz spa keeps going off says on readout
You have a problem with the RCD (residual-current device). This is the part of the plug that you have to push reset on before a current will flow. You can repair this by buying a new RCD plug and rewiring it or if you already have an RCD socket adaptor for another appliance, you can just cut of the plug on the pod/ pump and rewire it into a rubber plug and then plug this into the RCD adaptor and the lay z spa should no longer cut out. The RCD is important because you do not want to blow the unit inside.
I hope this helps, If you need more assistance, please ask.
Posted on Jun 12, 2010
Anonymous
SOURCE: lay z spa water pump is faulty where can I get a
Hi Im Chris From BVL Elecric,
I cover Bournemouth and surrounding areas and supply solutions to most home electrical problems.
A lovely lady customer called me out today to diagnose faulty
LAY-Z-SPA
pump/heater that kept tripping the RCD.
After scouring the net and finding this same problem over and over again but no solution,I decided to get personal with the blighter!!!
RESULT:- problem solved,
Customer very happy,
no new parts fitted,
water heating fine now.
If you live in my coverage area,have a LAY-Z-SPA that is faulty,no or limited warranty then give me a ring and I will be only to happy to come on over and fix it for a small fee.
just think that dead spa/pool heater/pump could be heating your water again tomorrow and there is plenty of summer left to enjoy it.
You can find my details quite easily , just google BVL Electric Bournemouth
Posted on Jul 02, 2010
MOTORWIZJ
Jay Finke
  • 1389 Answers
SOURCE: lay ze spa pump not working atall digital display
HAVE THE MOTOR TESTED. TAKE IT OUT AND PUT POWER TO IT. IT USUALLY IS THE MOTOR, AND NEEDS REPAIR
Posted on Jun 04, 2011
Lay z spa 6cf error code
This is the REAL answer if you see the 6cf error code it's to do with the plug.
I had the error code 6cf and it took hours to work out what was wrong and it was so simple... the pump unit needs to be plugged straight into the mains plug. Wont go away or work of your using an extension cable.
After I plugged it into the mains plug directly error code disappeared fully working.
Hope this helps people and saves them hours of dread thinking they bought a broken unit.
Jun 02, 2018 | Pool & Spa
My indoor lg mini split unit the cool light flashes 4 time what's wrong
Indoor unit faults = CH04 or C4
Fascia LED's
- RED = None
- GREEN = 4 Flash
Contents = Drain Pump / Float Switch
Case of Error = Float Switch Open Circuit (High Level Water Alarm)
Indoor Status = Off
clean your condensate drain line you can do this with a shop vac,
Read more: http://dgoma.es/multisplit_lg/lg-multi-split-units-error-code/#ixzz34dr3Cu00
Follow us: dgoma on Facebook
May 26, 2014 | LG LMN127HVT LMN127HVT 12 000 BTU Ductless...
What is error code 6cf on my lay-z-spa
How can i solve this problem?
Jul 27, 2012 | Pool & Spa
My washer keeps saying SUD. what is wrong?
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
Jan 31, 2011 | Washing Machines
My laptop has problem, it is not indicates charging light and also not charging so it can't start should i replace battery ? how can i run my laptop on dirict pluged in plz, give me idea
Well It doesn't seem to me the problem of battry so replacing it is not a gud choice if you want to confirm that then take out the battry off your laptop Plug in the power pin and press the power button see if it start on direct pluging if it does then it must be your battry which requires a replacement and if does not than you power plugin socket needs to be reparied. Hopefully this would help...
Aug 22, 2010 | Acer TravelMate 4220AWLMi Notebook
Layz spa keeps going off says on readout 6cf.heater is fine pump everything else is ok cheers kevin
Sep 30, 2009 | Pool & Spa
My front loading washer shows a code Err Loc.
there could be 2 things wrong 1 the pump had failed or the brushes on the motor have failed can you send me the error code thanks
shaun
Jan 13, 2009 | Frigidaire ATF6000ES Front Load Washer
It's not working
I have the same problem - I tried pluging it directly wall socket - still the same error - I did notice that the plug that connects the from the front load scanner to the flat bed was not really connecting all the way.. it looked like it was but i turned off the scanner and went ahead and made sure that both screws were in all the way (its a little tuff) and then turned back on the scanner - the error went away and it does appear the the connection was not being made completly - I was able to scan several documents. I see that some of you have this as a re-occuring issue. I just got this scanner for one of our locations. Hopfully it does not reoccure.
Aug 14, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Error code
be certain you have it plugged directly into a ac socket , no surge protector or gfic protector.
the main fan should have come on first then the compressor.
if not the fan capacitor or the fan is stuck.
try reseting it by
for resetting the error code. Unplug unit, clean filter, HOLD DOWN power button and CONTINUE HOLDING while plugging unit back in. Unit will beep. Unplug again, plug back in and resume normal operation
Mar 30, 2008 | Windchaser PACR10 Portable Air Conditioner
Fuji f-401 not recharging.
There is only two possibility why the battery didn't charge.
1) cradle ( socket at camera side ) faulty.
2) the power adaptor faulty ( no dc voltage,can use volt meter to confirm ).
it worth repairing .Thks
Dec 13, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Pool & Spa Logo
3,889 people viewed this question
Top Pool & Spa Experts
Bill Jordan
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
