SOURCE: maytag electric range shows F1 error message and beeps
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
f1 is a bad range
SOURCE: Timer on the Maytag range keeps beeping and shows F1
the F1 code is usually an internal failure of the control board. it may have a failed oven sensor that is causing the control to think it is over temp and the sensor is alot cheaper to replace first, usually about 50 bucks. to replace the control board will usually cost about 150-200 bucks. but try the sensor first.
F1 code means a defective touchpad or membrane, usually the touch pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: Disconnect the power to the range
Gain access to the back of the ERC (clock)
Unplug the touchpad ribbon connector from the clock
Make sure everything is clear & will not short out when the power is turned back on to the range. Replace any covers removed to gain access to the ERC.
Turn the power back on to the range
Watch for the F1 and listen for the beepIf you get the F1 and beep, replace the ERC (clock)
If after approx. 60 min. you do not get the F1 fault, replace the touch pad. Note: some ranges incorporate the touchpad and the clock as one part so F1 means a bad clock control.
