SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write. You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you. What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving. During the wash cycle, the top half is just sitting still. If this is wrong, please let me know. If this is right, you have a sort of simple fix. Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off. When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there. You can put your finger on the lips and lift it straight off. Then you will see a cap with a bolt in the center. Remove this bolt (7/16" with long extension). the agitator dogs (Sears part #387091) . You should see these under that last cap tha had the bolt in it. Remove the auger (just slide it up and off), remove the dog holding cap. Remove the dogs, but be sure you remember the way they go back in. Next is the tricky part. Take the cap upside-down, and place it back in the auger. Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole. Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator. Make sure the locks and stuff fit right between the two. Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap). If all goes well and right, you should be able to roll the auger one way and not the other. If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along. Good Luck!!!!! Jim
SOURCE: Whirlpool LSR7133KQ0 no pumpout, rinse, or spin.
NO...the problem you are describing are the typical symptoms of a lid switch malfunction. The lid switch shuts the washer off when you open the lid while the drum is spinning. This is a safety feature to prevent injury from moving parts if you decide to add a garment or stick your hands in the tub for some reason while it is in operation. On some model Whirpool's the washer WILL work initially for the wash cycle, then stop when it gets to the rinse cycle. I would recommend you check your lid switch to make it is not loose or broken. Your washer is also equipped with a lid strike (a small plastic piece on the lid that activates the switch) make sure it is not broken off or missing. This will give the same symptoms of a broken lid switch.
If you require a replacement switch, they can be ordered on line at searspartsdirect.com, or you can go to your nearest appliance parts retailer. The part number for the switch is 3949247. The lid strike (if required) is part number 358684. If you need instructions on how to replace the lid switch, you can use this link if you like:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
I don't know how savvy you are, so I thought I would add the instructions just in case. I hope you find all this information helpful. Let me know if you require additional assistance.
SOURCE: whirlpool washing machine gearbox won't
here is a good site for that.
http://repair2000.com/coupling.html
SOURCE: agitator won't turn and tub won't spin
The motor coupling is broken, the part located between the motor and the transmission.
