Question about John Deere Garden
Deere g110 mower, engine will click but will not turn over. New starter. Seems like blades are engaged. How can i tell?
Posted by ronaldhea267 on
  • ronaldhea267 Apr 05, 2012
    I am bypassing the key switch and brake switch, jumping straight to starter, it clicks but engine will not turn. It started last season making the clicking then would turnover.
mike butler
    Brigadier General:
  • 6,468 Answers
Use a pair of jumper cables and go from the battery to the starter see if the starter works try and jump it from your car it could be a bad starter
Posted on Apr 07, 2012
5 Related Answers
GM Elec
Bruce Bracey
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
Anonymous
  • 5 Answers
SOURCE: John Deere LA110 mower blades got disengaged
does it engage manually with a lever, or is it electronic with a push pull switch? if electronic, check the wire that goes to the electric clutch, it might have come off when unplugging it. do all this with the engine off
Posted on Jun 27, 2009
wireguy212
danny herget
  • 1627 Answers
SOURCE: I have a Deere LX188 mower, while mowing the
you need to check the seat switch first then have the park brake switch looked at.is there power to the starter relay?
Posted on Jul 23, 2009
wireguy212
danny herget
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
A Miller
  • 8404 Answers
SOURCE: John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
Posted on May 02, 2010
On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem
"On john deere la150, if i sit on seat and engage blades,,,nothing, but when i lift of seat, blades engage and motor shuts off. Replaced seat switch and did not fix problem" Okay, what I'm hearing is that "nothing" means the blades-driving PTO won't engage (declutch) when you switch on mower; but then, (say) as you start to dismount the mower (seat) the mower (drive clutch) engages even as the deadman switch (seat switch) kills the engine (and the drive/pto shaft starts to slow down. The key here seems to be that at full engine torque the clutch is unable to remain engaged but, rather, slips so that mower blade inertia (resistence) cannot be overcome...but as engine/pto rotation slows the clutch is able not to slip. First place to consider is the clutch gap which is probably to0 large (possibly from wear and tear, possibly not). So check specs and how-to from manual or factory and reset the pto drive clutch gap...not hard to do. If clutch gap is not the problem then most likely rehab or replacement of the clutch assy will be needed...is the mower has many years use sufficient to wear out the clutch. Another possiblity is an electic (wring/switching/grounding) problem involving mower and deadman switches.
Aug 19, 2014 | Garden
My 155c John Deere will not start! Brand new charged battery....I turn the key...nothing(no clicking either). When bypassing it to cellinoid, it starts right up. When I shut off the mower, I have to...
Usually when the key is turned to start position the starter soleniod engages thus applying power to the starter. There are three possible causes to your problem . (1) Check for 12vdc at the terminal on the soleniod when the key is turned to start position, if there is 12vdc at the terminal then the key switch is good. (2) loose or bad cable connection at the soleniod, check connections. (3) bad soleniod -- replace it. generally you will hear a click from the soleniod when the key is turned to start position. Also be sure to check that ALL safety switches are engaged. You may need someone to sit in the drivers seat so that switch will be "made" / engaged. Park Brake is set, mowing blades are "NOT " being engaged, on some mowers if the transmission is in reverse ,even tho the brake is set the mower will not start.
Nov 10, 2013 | Garden
Why does my john deere g110 blows fuse when blades are engaged
unplug the clutch and see try it if the fuse doesn't blow then look at the wires going to the clutch make sure they didn't rub on something
Jun 09, 2012 | John Deere Garden
John Deere 165 will not turn over. New battery has fuel. Engine clicks one time when I turn the key. Could this be starter or solenoid? How do I trouble shoot?
"One click" tells me it's a connection issue. Remove and wire brush the ground and battery cable connections at the battery, chassis, starter and starter solenoid.
May 22, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have a john deere L130 riding mower...while cutting the blades just quit turning...have checked the belt and the blades will turn by hand but won't engage with the switch
There seems to be a common problem with the L130. After reviewing the posts it appears that many people are having this issue. I had the same problem, it turned out to be the wires from the PTO switch at the clutch under the engine (right above the belt pully). The wires are breaking at the connection under the engine due to the vibration.
May 24, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 316 the starter doesn't engage often. Turn the switch get a click, again and again, finally the starter engages. If it doesn't start right off there is another series of clicks before it will...
You need to instal a starter relay kit.Deere part # AM107421.Mount it down by the starter,purple wire that goes to starter will now be plugged in to the relay,red wire to hot side of starter,black wire to a ground point,purple wire that is a part of new relay can now be plugged in to the starter.its very easy to install and fixes nearly 100% of clicking starter.
May 22, 2010 | John Deere 420,1020,2010,2020,2510,2520...
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Jun 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
359 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
