We are replaceing the lamp with a new lamp and lamp housing. Is there anything thing special we need to do other than slide the old housing unit out and slide the new one back in? The reason I ask is because we replaced it and our lamp light in front is still blinking.
Nothing else is required except inserting it right which is not hard==lamp does not seem to be your problem, Other things will cause this issue as well, it is not always the lamp that is bad.
One thing you might want to do is remove here the new lamp unit to make sure it went in clean and straight, With it removed look in the direction the lamp faces for the color wheel, look to see it is intact and not shattered, I attach a photo.
I mention as this is also a common issue in this set, usually proceeded by a high pitched fan like sound or even when failing a grinding noise.
SOURCE: Issues with replacing Ballast
I have some proble dlp tv I put new lamp;put the problem didnt whant away
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
SOURCE: installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
SOURCE: Just baught a new lamp and all that is happening is lamp light...
You will need to reset the lamp counter.
Press:
after using this combination, you can subsitute MENU instead of MUTE.
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
