Samsung syncmaster 275t won't start, I have it working fine during some years now but in 2010 Nov.I had to unplug and store it until some issues where solved (not related to the monitor anyway).Now I'm trying to use with my notebook (Acer) with ATI RADEON HD4330 latest driver and window 7 64-bits. This is the third day I tried and won't work. Details: I brought an adapter with a female DVI and a MALE VGA to connect with the notebook and all is normal to look but the display on the Samsung Sync-master 275t continues to flash the blue light in the start button and won't stable, only flashing on and out. I try to push the 'auto' button and nothing the 'source' button and displays the 'digital' label. I disconnects from the notebook and shows the blue and white label/Trade mark from Samsung flying around the display with a note saying: Check signal cable: DIGITAL What do I do? To fix such issue? thanks CG
The Samsung monitor is okay, the problem is a compatability issue between the laptop and monitor. The VGA toDVI is the problem you are converting a analog signal to digital, the signal level degrades when that is attempted. If I understand this the laptop puts out the analog signal "VGA" and the monitor has the DVI input, "digital" The only other suggestion is turn off the laptop screen to see if the monitor will work.
SOURCE: i have the Samsung Sync
did you try other VGA cable? because this usually happen went you using bad cable.
dm
SOURCE: Have A Samsung 940Bw connected via DVI connection
First thing I would try will beusing this monitor with another PC using the same the same setup to see if it works OK. We need to narrow down the cause of the problem first since you have three parts that can be bad; Monitor, DVI cable, PC Video card/PC. It is just a process of elimination to locate the problem. Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
I'll try this out. thanks to help me.
well I did try to use ONLY the digital monitor the extra one, but the monitor of the Notebook has no option to turn it off and use only the digital(extra one) it's a Radeon 4330 - 512 MB which gives no possibility for it. So I'm stuck with the problem...
Can't figure how will try the samsung syncmaster 275t in other notebook, since I'm in a foreign country where I don't know anyone to ask for a test ...
Any clues besides a test with another computer?
Thanks
CG
Thanks
CG
