How do i turn fax confirmation off
SOURCE: Fax confirmation
Hi TUlsi The majority of fax machines will do this, I know as the ones i use in DHL are the same when i contacted the company Cannon they advised that it could not be disabled. Which give the solution, All faxes are different and you will only know how to disable it by contacting the manufactures support. I agree full it is anti enviromently friendly and a waste of ink
You can turn off confirmation report in USER TOOLS/FAX FEATURES/KEY OPERATOR SETTINGS/USER PARAMETERS Each user parameter has a set of switches, and each of the switches consist of eight bits, whose value is 0 or 1. The right most bit is bit 0 and the left most bit is bit 7. Once you are in USER PARAMETERS select switch 3, set bit 0 to 0 and set bit 5 to 0. To toggle between 0 and 1 for bit 0, press the 0 key. To toggle between 0 and 1 for bit 5, press the 5 key. Bit 0 sets the confirmation report for memory TX Bit 5 sets the confirmation report for immediate TX. Robert
SOURCE: How do i program the machine to only print out failed fax confirmation?
Please post you question again. We can't read you question.
SOURCE: How do you program the machine to only print out falied fax confirmations?
Yes. SmartDeviceMonitor for Admin and Web Image Monitor let you remotely view a device's transmission history as well as its saved destination data. You can install SmartDeviceMonitor for Admin from the CD-ROM that was included with your device, or download it from the device's website. However, SmartDeviceMonitor for Admin can only be used on a computer which has the TCP/IP protocol correctly installed. Once you have confirmed that SmartDeviceMonitor is installed, to confirm that your fax was transmitted properly, follow these steps: 1.Open SmartDeviceMonitor for Admin by clicking [Start] on the taskbar, pointing to [All Programs] and then [SmartDeviceMonitor for Admin], and then clicking [SmartDeviceMonitor for Admin]. 2.Click the device whose information you wish to display. 3.On the [Tools] menu, click [Load Fax Journal]. 4.When Web Image Monitor opens in your web browser, click [Job], click [Fax History], and then click [Transmission].
