I replaced the lamp in my samsung television and now there is a terrible burning smell i replaced it with another bulb and the burning smell is still there. also after taking out the bulb and looking inside there seems to be a small burn mark on an aluminum piece on the right side where the bulb was. can this be fixed? will the smell go away? do i need a new tv?
SOURCE: Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
SOURCE: Samsung HLR5667W lamp replace
The Problem you all are describing is a faulty light tunnel assembly it is common on most DLP projector sets.
Something I would not recommend attempting if you don't have the skills, It involves taking apart the optical system of the engine, you could have it repaired from an authorized service center for under $400.00.
SOURCE: SAMSUNG TV MODEL # PCL541R bulb not working
With the model number you gave, it comes back to a 2002 model in which DLP sets were not out yet. That's a conventional projection set with 3 picture tubes. Check the model number again?
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
SOURCE: Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
sorry just noticed that the model number is wrong it should be HTL6187S
SD Tech i took ur advice and took my tv to the Dr. I will keep you all updated on what the problem is
ok found out that when i shifted my tv to replacce the bulb i loosened dust inside the set. the dust was then being burned by the heat from the bulb. it would have burned off but i got the inside cleaned. now i know to vacuum the vents on a monthly basis to keep it from building up dust.
