Question about Delta Faucet Delta 467-SSSD-DST Palo Diamond Seal Kitchen Pull-Out or Out Faucet Brillia
Delta 467 faucet - black rubber piece covering spray button is cracked.
I have had a Delta 467 kitchen faucet for four year now, and the black rubber piece covering the spray button is cracked. Is there a way to replace just this piece? The part shouldn't cost more than $5, but it looks like you have to buy an entire wand assembly which seems ridiculous.
3 Related Answers
Randy Marshall
  • 349 Answers
SOURCE: How do I tighten a Delta kitchen faucet that has
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
Posted on May 15, 2010
Anonymous
  • 760 Answers
SOURCE: Delta side spray replacement
Delta makes sprayers to match the faucet design. Functionally they're about all the same. GO to theirr web site: http://www.deltafaucet.com/customersupport/index.html
If you don't know your model number you can use their wizzard and identify your faucet model. Then go to the parts section. One difference on the number you listed is I believe on comes with the mounting fitting that attaches to the sink. Some don't have it if they go through the faucet base itself.
Delta faucets have lifetime guarantee, I'm not sure if that includes the sprayer. (I doubt it)
Posted on Jul 11, 2010
Randy Marshall
  • 349 Answers
SOURCE: Delta Faucet Company 467-SSSD-DST Palo Diamond
I hope this will help please go to this web site for a downloadable parts link. If it is leaking from the spout replace the seats and springs to correct the problem. Turn water off and remove handle with a 1/8" allen wrench and remove retaining collar to access the ball assembly to remove the seats and springs.
The parts page on this link will give you a break down and hope this will help.
http://www.deltafaucet.com/kitchen/details/467-SSSD-DST.html
Posted on Dec 30, 2010
Delta faucet #467-DST. The last couple of weeks my kitchen faucet doesn.t want to turn back and forth easily. I thought it might be a kink in the sprayer hose. Help
There are two rubber o rings under the spout, one at the top and one on the bottom, Remove the handle then the nut that you will see that is in contact with the spout. Rock the spout left to right and pull up at the same time. You then can replace the O rings and make sure you put some food grade lub on the O rings. Replace all that you took off and you are god to go.
best of luck Rich
Sep 05, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
I have a Delta kitchen faucet model #467-SSSD-DST. The cold water flow and/or pressure is not adequate. The flow and pressure from the hot water side is fine. What may I do to fix my cold water problem?
Take the handle off (set screw underneath)
Then turn the top off under the handle....make sure water is off...
then you will find a ball with the handle stem on it....note the position of it and pull it out...
under there are two wets of springs and rubber seats...
pull the right side out and check the hole for a blockage...(dirt or rust)
if none is visible, you may have to unhook the cold water supply hose
and then blow compressed air back through the hole to remove the blockage...
then reassemble...
heatman101
Mar 20, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
I have a Delta kitchen faucet Palo 467 series. I am having a difficult time switching between spray and stream on the wand assembly. Occasionally it will "lock" into one position or the other and...
Are you using a softener in your home? Sometimes hard water deposits can clog up the cartridges and create the problems you such described. Im not sure about the lock/button issue though since I have never used this particular Delta faucet myself, but with one problem, it can usually cause many others.
Try replacing the cartridge on the Delta faucet first, Here is a link to the replacement one from the Delta site. http://www.deltafaucet.com/repairparts/details/RP50587.html
Here is a link to Delta warranty and lifetime guarantee. http://www.deltafaucet.com/customersupport/warranty.html
Here is a link to the Delta page with lots of useful information on your product. http://www.deltafaucet.com/kitchen/details/467-DST.html
Ex-Plumber
Hope this helps-
J.Sper
Mar 06, 2011 | Delta Faucet Delta 467-SSSD-DST Palo...
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Delta Faucet Company 467-SSSD-DST Palo Diamond Seal Technology Pull-out Kitchen Faucet, Stainless, 3 years old and is beginning to drip unless we position the handle just right. Is there a washer? I've...
Dec 30, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
It sounds like the cartridge is going or is possibly loose, If you take the handle off you can try to GENTLY tighten the cartridge and see if that fixes the leak. You don't have to tighten it a lot to see if it will stop; if you over tighten you can cause the housing to split and you don't want to strip the cartridge head because you may have to remove it. Use a proper set of channel locks and apply some gentle pressure if it turns and the leak stops, great! if it doesn't then the cartridge has failed and needs replacing. Your Delta faucet is covered by a limited lifetime warranty so the part should be free. Here is the warranty and the contact information to order one.
https://www.faucetdirect.com/index.cfm?page=product:warrantyPopup&uniqueId=2417692
If you are not comfortable dealing with plumbing issues I would highly recommend calling a licenced plumber. The part is free so its simply the plumbers time.
Good luck.
Oct 18, 2017 | Delta Faucet Delta 467-SSSD-DST Palo...
I have delta palo model kitchen faucet that has a
Delta faucets have a lifetime warranty. Call them and tell them, they will send you a rebuild kit. You can rebuild the whole faucet, it will work like new again.
May 02, 2010 | Delta 467-SD Palo Single Handle Kitchen...
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Delta Faucet Delta 467-SSSD-DST Palo Diamond Seal Kitchen Pull-Out or Out Faucet Brillia Logo
667 people viewed this question
Top Delta Faucet Plumbing Experts
Muntejaya Ginting
Muntejaya Ginting
Bill Johnson
Marvin
Marvin
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
