Question about Samsung ML 2010 Laser Printer
Online/error light is red Samsung ML-2010PR
Online/error is red cannot print documents
5 Related Answers
Anonymous
  • 385 Answers
SOURCE: error msg
Hi Usually with this printer, you just simply turn it off and then on again and the lights will stop flashing. This is an LSU (Laser Scanner Unit) error. If you still have the problem, it might be either the LSU needs replacing or it could be the main board. These parts might be scarce though and very expensive. It might almost be cheaper to buy new printer but that is up to you to check and decide for yourself.
Posted on May 25, 2007
Anonymous
SOURCE: online/error light
Pull out the toner cartridge. Carefully put your fingers into the opening just beyond the chrome roller. A little to the left of center you will fell/see a small black plastic finger which sticks up. It should be loose - push it forward and it springs forward, release it and it returns to the original position. If your paper jam catches this finger it can become jammed and will feel rigid. Put light pressure on it either pushing to the back or pulling forward until it becomes free again. Replace the toner cartridge, close the cover and your red light should go out.
It worked for me - hope it helps someone else.
Mary Lou
Posted on Oct 22, 2008
Anonymous
SOURCE: ML1610 SAMSUNG PRINTER PROBLEM
The online/error light is always red, and I can't print. I turn the printer off, change the toner and the light is still red, what can I do
Posted on Feb 05, 2009
Anonymous
SOURCE: Red light on all the time will not print
Depends which LED light is red. The upper one with two symbols is the error LED, while the lower one is the toner LED.
If it's the top LED, then it could be a number of issues, such as an open cover or some software problem. Could be an LSU error. Try updating the driver and firmware.
If it's the bottom LED, then your toner is probably finished (or has hit the 2100 mark). Try redistributing the toner by giving it a little jiggle, or just change the whole thing.
Posted on Jun 12, 2010
Anonymous
  • 122 Answers
SOURCE: The online error light is red on my ML-1610 Mono
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Posted on Jul 16, 2010
Testimonial: "Very helpful!"
3helpful
The red light is on how to repair? (On line/ error)
the red light (online error) means that the printer is off line. How do you fix it? you press the "ok" or "reset" button and it puts it back on line and ready to print.
1helpful
I NEED TO INSTALL THIS PRINTER SAMSUNG ML-2010PR MONO LASER
Drivers for Samsung ML-2010 are available at Samsung official site OR here
Select the operating system and download the drivers
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
1helpful
I have a samsung ml 1740 & its not printing, I have an error/online light on red and it does not seem to beable to pick up the paper?
unplug then plug it in again. after u hook it up with the computer try turning it on and off before u start printing!
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
4helpful
2answers
On Line / Error light red and printer can't work on ML 2010
Derek Kwaku Asamoah box mc 279 Takoradi. Please am using your product "samsung ml-2250 printer" and the problem is that the online/erro light is on. thank you for your co-operation and i hope to hear from you soon.
Samsung ML 1710 won't print second page
i'm thinking it's a config-related problem. i've seen a comparable problem already. could you check the settings in the printer software? there is setting that says "print first page from different tray" if its box is checked, the printer wants to print the rest of the print job from another tray, and will block when there is no other tray available.
if you find this setting is not marked, then i propose to delete the printer driver and all settings and then downloading the most recent driver from the manufacturer's website and installing that one.
Red Indicator Light stays on-- "Online Error."
tray to powering off the printer wait about 10 second then swith on
i use to be too
Samsung ML-1710 Printer: Online/Error (red) lite ON: won't print
It is not a computer problem, when your printer won't come to ready. The lights flashing are due to a failure of some sort - electronic, or perhaps a fuser warm up problem. The fact is, whatever the fault, it is cheaper to replace this printer than have it repaired.
14helpful
2answers
Samsung ML 2010 Laser Printer Logo
Top Samsung Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
