Model #ed5hhaxvq02. red light is blinking twice on ice maker control. dispenser motor in door is working and water in door is ok.
SOURCE: Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
SOURCE: Whirlpool Model GS6NBEXRL01 ice maker not making ice
Most likely the water control valve on back of the refrigerator near floor or the thermostat inside the ice maker is defective. You can fill the ice maker with water from tap and see if it cycles one time or you can check the control valve solenoid that feeds water to the ice maker. Click on link below and then paste your model number in model search feature. That takes you to a page with breakdown photos of the parts I mentioned. On the left of your screen click on photo # 12. If you need help with this I am here, just let me know, Sea Breeze
http://servicepartstec.blogspot.com/
SOURCE: Ice maker not dumping out ice
Your ice maker has a heater on the bottom of the tray that heats up the tray enough to allow the ice to release from the tray. It's energized when the ice maker advances to a point that the fingers touch the ice. There is a micro switch inside the head that turns the heater on. You will need to remove the ice maker to repair it. You should have two 1/4" bolt on the top and one or two on the bottom ( Don't know which model you have). If I knew the model number you have I could tell you what you would be looking at after you pull the front off the head of the ice maker. There are two major types. One you can test while still mounted and the other you can advance only. Once you have taken the unit out, you can ohm the heater. If it's good, your problem will be the micro switch. It cost around $8.00. If the heater is bad, you can replace it, but It's hard to do and I think you will find it will be better to replace the ice maker. I have replace a few and around half didn't work afterwords due to them breaking while installing them. You have to bend the metal over the element ot install and it's tricky to do this without breaking the element. I Hope this helps. Please rate my solution. Thanks
Testimonial: "Thanks for heading me in what appears to be the right direction. Will"
SOURCE: Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Testimonial: "Will try suggestions. Thanks!"
