I need to entirely wipe and reformat my laptop hard drive. There was a problem with major, multiple viruses and has now been corrupted(I believe). I need to simply wipe the drive entirely so that i may securely install a new OS. The system last had windows vista and due to a failed installation, currently has no OS.
Download MiniTool Partition Wizard Bootable CD 7.1 from Here.
Or Download Directly by Clicking here
This CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?
1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
2) Click Delete All Partition under Disk Operations in the Action Panel.
Note: May cause Windows to not start properly when used on
partitions containing the boot partition or system partition.
memory wipe wd3200bevt - 4_4_2012_9_03_34_am.jpg src="/uploads/images/4_4_2012_9_03_34_am.jpg" alt="4_4_2012_9_03_34_am.jpg" class="h_mi" />
For more information check the website Link
Hope this will be useful for you.
Best Regards
Nandu
SOURCE: I have a Toshiaba laptop which had a hard drive
You can install the windows to follow this step.
Make sure that the CD drive is on first boot. When you turn on your laptop you need to press the delete key fast, to access the BIOS. Once you have change the BIOS settings you need to save it. After you save once the laptop detecting the windows CD press the enter key fast also to boot from CD.
Soft reset/reformat - Type *#7370# and the phone's lock code (Nokia default lock code is 12345). Warning!Soft reset wipes the C drive/phone memory!
Hard reset - Switch the phone off. Press and hold three keys together, the green key, the * key and the number '3'. While you are holding these keys, switch the phone on. Don't release these three keys before you see the NOKIA logo.
Warning! Hard reset wipes the C (phone memory) drive.
