Bought new memory card 8mb and there is a card error message also need to buy a new manual for this camera.
The camera uses SD cards. I assume your new card is 8GB, not 8MB as you stated. If this is the case, it's an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the SD-only camera. You need to use SD cards, 2GB and smaller.
You may download a copy of the manual here.
SOURCE: I have a Gateway DC-M42 digital camera that I
hi
two things here
have you checked if the meory card is the right type for the this particular camera
do this camera support a 4GB Card
cheers
pls rate if this was any help
SOURCE: i have a gateway DC-T50
Is it an SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
SOURCE: where can i buy cf
You should be able to buy CF cards at just about any camera, department, electronics, or office-supply store. Some drugstores and supermarkets carry them as well.
