This HDD is from laptop Toshiba Qosmio f45-av412. The disk is taking over 20 hours to format it. Is this normal?
SOURCE: hard disk
if you are installing a dos based system thn dos formatting is very good
if you are going to use xp then make boot option in setup as bootable from cd rom
put a win xp setup cd in the cdrom drive
it will boot up saying press any key to continue , and follow the scren instructions
the whole process is that simple a hd can be formatted till bad sectors are not shown up upto 8 %. more thna 8& bad sectors cannot load windows, however dos can still be loaded and so also win me so it doesnot affect the hd
what affects is the jerks and voltage supply variations on the har d disk and some bad virus infections and the temperature the hd has ... always leep hd at a tem p lower than 37 degres c
use a fan to achieve this a 12 volt small fan mounted on the hd .
SOURCE: harddisk Bad sector & not detecting
Hi, If your partitioning and/or formatting program is already reporting "bad sectors", then your best bet is to replace the hard drive. The mere presence of bad sectors indicates drive problem which in the normal course of time/usage would increase and eventually make the drive inoperable. Using such a drive as your "C" and/or to contain mission critical files may not be to your advantage. Hope this be of some idea/help. Good luck and kind regards.
SOURCE: Formatting HDD
just go to bios and make the first boot device as cd rom then you save and exit, insert you installation cd in the rom and follow the instruction,
SOURCE: Slave HDD not formatting correctly and displaying low capacity
If the bios does not see it at anything bigger than 9MB then the system will not do anything more than that. Did you install the drive on the same cable as your primary drive? If so make sure that the jumpers are correct. Try puting the drive on the secondary cable with nothing else on the cable. If you do have it on the secondary cable Im going to guess that you have a CD rom or DVD rom on the cable. You might try puting the jumpers on cable select for both devices remembering that the one on the end of the cable will normally end up being the master. Try just working with the secondary cable so that you dont have any issues with drive conflicts with the Primary master drive. Once you see the full drive amount in the bios then you can format the new slave. Fat 32 is the flie system of choice for Win ME so try the newer file system after you see the full drive size in the bios. I use a program called casper XP but you can get a free program from most drive manufacturers. I like the Western Digital Lifeguard program. Its easy to use and works on almost any drive. Hope this helps... Dale
SOURCE: Formatting a Samsung MP0804H IDE extrernal HDD from NTFS to FAT32
Hi there Dave, well you can use a software called Partition Magic 8 to convert your 80GB hard disk to utilise FAT32. This software is quite user friendly. There are several options for you to choose form in this software including resizing your drive and creating partitions on the fly. However some settings requites a computer restart or reboot in order to complete successfully. This software can be obtained from most software stores or even download form the internet. After installing the software and running it, your drive should show inside the programme; right click on the drive you want to change a setting and select the options available. At the 'Format' button select FAT32. You will be asked for drive letters and cluster size but you can use the default settings, then apply the settings. Once you are done with that select the Okay button in the main programme window and the formatting process will start. Hope this helped you. Cheers :-)
I apologize for not giving enough info: OS Windows Vista Ult.., formatted monitored Toshiba Recovery cd. I ALWAYS clear the vents.
I want to install windows me
