Philips GOGEAR SA6045 MP3 Player Logo
Question about Philips GOGEAR SA6045 MP3 Player
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
When i connect it to my pc there is a message on the player screen that sates "Chose any connection type.....Charge & play. or Charge& transfer the the screen gos dead and the devise is not being charged
Posted by gordon_gi724 on
Anonymous
  • Philips Master
  • 32,281 Answers
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Apr 04, 2012
5 Related Answers
Anonymous
  • 116 Answers
SOURCE: how do i charge the Go Gear Vibe MP3 player?
You can charge it either by connecting it to your PC via a USB cable supplied in the box, or get a universal USB charger to charge it directly form an AC outlet.
Posted on Feb 25, 2011
Vicki Sutton
  • 3 Answers
SOURCE: i have a phillips gogear vibe 4gb mp3 player, and
I had the same problem until I installed the cd that came with it. Now it shows up right away. Hope this helps.
Posted on Dec 27, 2009
aliasger yq
  • 219 Answers
SOURCE: gogear vibe 4gb cannot be turned on
check battery voltage
Posted on May 31, 2010
Gyula Lacz
  • 486 Answers
SOURCE: When i turn on the
You can repair your device via this link:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=ePlatform%20-%20Philips&scy=US&slg=AEN&sct=FLASH_AUDIO_PLAYER_SU&cat=MP3_MEDIA_PLAYERS_CA&grp=SOUND_AND_VISION_GR&session=20110215050442_93.189.114.198&ctn=SA1VBE04K/17&mid=Link_DiagnosticInformationTool&hlt=Link_DiagnosticInformationTool
At first click on "Repair/Update" and "how do I repair.." and go on step by step. Finally you should get to "connect device in repair mode" and do all described there and I hope your device will come back to work again correctly.
Thanks. Good luck!
gylacz
Posted on May 23, 2011
Anonymous
SOURCE: My Philips GoGear ViBE Digital Media Player
mine nether
Posted on Jun 12, 2011
Its not connecting to pc
check the file format reformat the MP4 player to NTFS use the administrative tools and ccheck that device partition on wich format is it on!
1helpful
My eclipse cld 4gb mp3player wont hold a charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
How do I charge my mp3 video player
Charge your GoGear player battery quickly and easily from your PC via USB. By connecting your player to your PC with the cable provided and following the necessary prompts, your PC will provide the power for charging your player within a few seconds. Enjoy the convenience of doing away with a separate recharger.
MP3 player won't power up. I was listening to it and it just went off. Thought battery went dead but tried recharging. Nothing happens when I try to power it up. It's a Phillips Model...
Hi ronnie641,
Here is the Support Site for the Philips GoGear Vibe:
http://ow.ly/5QSk4
You can find FAQ's, as well as instructions on how to perform a Repair (see below). A Repair will restore the device as well as update the firmware.
If you have any additional questions, you can reach Philips Consumer Care @ 1-888-744-5477 - an agent can also guide you through the process.
Hope this helps!
REPAIR INSTRUCTIONS: http://ow.ly/5QSon
Use a pen tip or other sharp object to insert the RESET hole gently on the side of the player and connect it again to your PC.
If it is still not recognized, your player may be at fault. Try the Philips Device Manager software.
NOTE: Contents will be removed by using the repair function.
  1. Install the Philips Device Manager and run it with your player connected to your PC. You can download it under the Software & drivers section.
  2. Click the Repair tab in the Device Manager, press and hold the corresponding recovery key on the player when connecting it to your PC.
  3. Follow the PC screen to recover your player.
You can find the recovery key on your player from the below table.
My Go Gear device was charging and then it froze. I tried turning it off, unplugging it, and even connecting it to a different charger. And my computer won't pick up the Go Gear device when I have it...
T osolve this problem, wait until your gogear device dies and wait for 3 hours. after that, recharge your device. This will occasionally happen to this device. (from personal expierience). I recomend the ematic tocuh screen ipod for only 65 $ on walmart. works very good
I juat purchased a pholips go gear vibe mp3 8 gb. is it a rechargable player?
Most media players have a rechargeable battery and it is charged by connecting the media player to USB cable and then plugged into the USB port on a computer.
Phillips go gear vibe 4gb mp3 says drm license expired owned it for only one month
Philips gogear vibe 4gb says its full then it says to delete some content. I deleted every thing and it still says that.
How do i put pictures on phillips go gear vibe 4Gb mp3 player?
hi my philips gogear 4gb vibe wont download pictures off my computer. but when my daughter plugs up her new ipod, it downloads them. can you please tell me why this is and how i caqn get pictures on mine? thanks
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
David Shaub
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
