Computers & Internet Logo
I have a ups 500 the battery is dead how to check the ups will work on new battery
Anonymous
    New Friend:
  • 57 Answers
What is ups?
Posted on Apr 04, 2012
Battery on 1984 shadow 500 is not charging. How do you check the rectifier/alternator? wiring looks(?) good.
if it is a new battery and not an old dead one,then you need to replace your regulater/rectifier
Polk Audio DSW Pro 500 remote doesn't"t work. I've tried replacing the battery and was told by another technician to take the sub-woofer out and make sure the cable is plugged up to the amp and the IR...
Is this NEW? Or did it just fail spontaneously after working for awhile?
Is this just a remote control issue or is the sub dead, too?
From the manual...
No sound coming from subwoofer.
If hookup is "SUB OUT" to LFE, check and make sure your receiver is set to Subwoofer=YES. If hookup is via speaker wire, check that the polarity of the wires is correct.
Subwoofer has no power.
Is the AC MAIN switch on? Check outlet; check fuse after unplugging the subwoofer. The fuse is located under the power cord
receptacle. Fuse type and rating is found on the back panel.
Remote control doesn't work.
Remove the plastic tab to activate the remote control's battery or try replacing the battery. Ensure the IR sensor is not blocked.
If it's a new problem with a previously working remote...
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12954406270641
It describes a way to possibly fix your remote or at least prove it works or doesn't.
Find new or replacement remotes:
http://remotes.com/remotes/servlet/rs?a=Display&contents=home&uuid=A12992635562861
or eBay: search for "(model) remotes", check the 'include description' box. Usually cheaper than the vendors.
2helpful
2answers
1995 dodge stratus keeps going dead in driveway. I jump it off and let it run 15 mins to charge battery up. Turn off and crank right up, but the next day it is dead again.
With engine running used a voltmeter and check voltage at battery, you will be checking alternator out put voltage, should have a reading of no less then 13.0 volts, if less bad alternator, the reason it keeps going dead is that the car is using the battery to run it .till the battery has no more power, then you jump it and the battery is charge up again and will run again till it goes dead again.
3helpful
3answers
2007 Polaris Sportsman 500 won't start. New
1999 polaris 500 sportsman, changed battery and now front lights will not come on. Suggestions?
Oct 22, 2009 • Polaris ATV
1helpful
2answers
Predator 500 batery wont stay charged
volts dont make things work it is the amps your battery is going dead the battery need to be replaced
Jul 20, 2009 • Polaris ATV
Power
your battery is all the way dead and needs charging, or your battery is not holding any charge and you need a new battery, or, worst case scenario, the phone battery contacts are not working and your phone is now incapable of using a battery.
94 pathfinder wont start seems like dead battery but is charged t
If you have had the battery checked, attempted to jump start or know for a fact that the battery is new and/or should not be dead....you may want to have your alternator checked out - it may need replaced. When alternators go bad they mimic the effects of a dead battery (tries to turn over, battery light comes on, etc.) Hope that helps - you can pick one up and install yourself for around $150 bucks or 400-500 to have someone else do it for you.
700 1984 Honda Shadow
charge the battery else replace a new battery and check it periodically..
Marvin
Marvin
