SOURCE: Have a Husqvarna riding mower
For a riding mower to start, all of the safety interlocks must be "made".
The brake may have to be set.
The transmission may have to be in neutral.
The blades must be disengaged.
The driver may have to be in the seat.
If one of the necessary interlocks is not "made", the mower will not start.
Gary
SOURCE: Won't crank--some kind of electrical problem
Disconnect the (battery) starter cable and check with a multimeter the continuity of the starter relay thru the relay terminals which connect the battery to the starter (key will have to be turned to start) -- if you get continuity, it's likely not the relay, but I'm with you, it sure sounds like the relay (solenoid).
P.S. Running a starter directly off a charger is a good way to burn up a charger.
