Black screen flashing dash top left corner. ....wont reboot after system restore
I have a samsung np300e7a-a04uk totally black screen flashing dash top left corner. Ive tried total system restore but it wont reboot and when I turn it back on just shows press f2 or f4 then goes black again,,help please
  • solsticemoon
    solsticemoon Apr 03, 2012
    blinking thing is only 3 months old!!
  • Computers & ... Master
  • 27,725 Answers
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Posted on Apr 03, 2012
6ya staff
SOURCE:
IQUIT
  • 3940 Answers
SOURCE: wont load windows got a
Most likely a hard drive issue. Might have a corrupt boot sector, might be a failing hard drive. Remove HDD and see if you can boot to a windows CD, if you can then the issue is with the drive.
Posted on Oct 09, 2010
Anonymous
SOURCE: hp laptop wont restart
google translate sucks so so so so bad
Posted on Aug 24, 2008
Anonymous
SOURCE: my acer travelmate will not boot up, please help
Well I have the same problem, I think it is a BIOS problem because after the acer screen it says Windows did not start succesfully. I saw start Windows normally but it has that "blink of an eye flash" as well, then it goes back and tries to boot up again. Maybe take it to a shop to get fixed.
Posted on Sep 06, 2009
Anonymous
SOURCE: My Acer Aspire 5100 wont start up correctly
I had the same problem after running an update to my Norton anti-virus software. When booting the laptop, press F2 to go to the setup menu. One of the options allows you to change the order that is searched when booting up. I moved the boot from hard drive to the last option, allowing it to boot from a network first (which it doesn't find), then from a portable device second (which it doesn't find), and finally from the hard drive. When I boot up, after it doesn't find the first two options, it boots from the hard drive with no problem.
Posted on Nov 12, 2008
NinaE
  • 3278 Answers
SOURCE: My Dell Inspiron 1520 will not load
Hello, Beth.
The most common reason is memory. Try reseating (remove and reinsert) the memory, first.
Power off the computer and disconnect all cables. Flip the laptop to the back. Remove the battery. The memory cover has 8 screws. Remove the memory modules at a 25 degree angle and reinsert them by pushing them down firmly by the ends.
If reseating the memory doesn't solve your problem, one module may be bad. So, remove and test each module one at a time.
Hope this helps.
Posted on Nov 23, 2009
Acer-E1-510. Why is screen blank and system reboots but nothing?
remove the battery and replace it and try again if that does not work it could be you boot files are damaged and you will need to do a system restore
Feb 20, 2016 | Computers & Internet
White cursor in upper left corner
Remove ALL media, DVD, CD, USB, etc. Unplug, remove battery, plug in, reboot, at boot start tapping F-10 to do a System Restore, use this procedure to restore to a date before this issue: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&prodSeriesId=3832468&objectID=c01634414#A1 Post results.
Feb 02, 2013 | HP Mini 1000 Netbook
Flashing white dash with black screen
Sounds like your MBR is missing. In the top left corner? Like a blinking cursor? If so it's looking for a DVD/CD to boot from. Try to unplug the machine, wait 30 seconds or so, plug in Try to reboot. If that fails, Do a system restore/recovery at boot using F key. OR ,load Repair disk and reboot from DVD/CD rom.
Dec 16, 2012 | Dell Computers & Internet
Problems with compaq presario cq56
open f10 go to diagnostics 10008 bios code means the hard drive is fried new one for cq 60 160gb hard drive 90 dollars but might as well upgrade 500gb only 115 i would think the cq 56 should be about the same price
Apr 01, 2012 | HEWLETT-PACKARD Computers & Internet
42 inch plasma Samsung less than a year old with a crack in left corner has sound black screen??
Hi, If the warrenty is still good bring it back to where you bought it. In time the screen will go totally black. So replace it. Good luck.
Jun 20, 2011 | Televison & Video
Samsung 205BW ( Black ), turns on and for a sec it displays on the top left corner a little squere where it usually says Digital/Analog input, after that nothing more on screen, power led remains lit and...
The processor ic is not doing it's job, it controls on/off functions as well display and Samsung logo, input devices and more, if you checked out the power supply, you have covered everything within limits. This item is not cost effective to repair. Judging by your description the processor ic has been totally compromised.
Jan 07, 2011 | Samsung 205BW (Silver, Black) 20.1 inch...
Wont boot up, stays on black screen with flashing "_" sign
The OS probably has a corrupt system file that is causing it not to turn on properly. If you can get into safe mode, back up all of the files that you need either online or via a flash disk or blank CD/DVD. Make a list of the software you have that is downloadable from the internet, etc. as well. Once you are sure you have enerything, either burn recovery disks or use the recovery disks provided with your computer and wipe the hard-drive. This will make your computer like it was the day you opened it. After this is completed, restore your old files and you should be good to go!
Apr 13, 2009 | Acer Aspire 5100 Notebook
Hp pavilion a1017c will not boot totally stops at the blue screen
it's windows problem
format your system or reinstall your OS
may be virus on your system
Jan 20, 2009 | HP Pavilion dv8000z Notebook
Green Light on, but nothing working.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/power.jsp#shut_off
Dec 11, 2007 | Nintendo Wii Console
Computers & Internet Logo
711 people viewed this question
Ekse
Marvin
Marvin
