Ovens Logo
Gail Fox Posted on Apr 03, 2012
What does JJJJ 055 mean?
It's possible a little liquid dripped into the control panel. Sometimes it flashes to JJJJ jjj
Why does the oven time flash but the oven won't turn on?
power to the unit by removing one or more fuses or tripping one or more breakers at the main entrance panel or at a separate panel. If the range is fused at a separate panel, this panel may be located adjacent to the main panel or in a basement, crawl space, or other location. If there is a grounding wire to the range, disconnect it. Make sure the power to the unit is off.
Servicing FusesIf the range or oven is receiving power but doesn't work, the unit may have its own fuse or circuit breaker assembly. This assembly is usually located under the cooktop of the range. In some units, lift the top of the range to gain access to the fuse assembly; or lift the elements, remove the drip pans, and look on the sides of the cabinets. Inside the oven, look to the back to spot the fuse assembly.
If the unit has this additional fuse or breaker system, components such as the oven light, the range heating elements, the timer, and a self-cleaning feature may be separately fused.
If these components or features fail to work, don't overlook the possibility that the fuses have blown. To replace a blown fuse, unscrew the old fuse and install a new one of the same type and electrical rating. If the unit has circuit breakers, push the breaker or reset button, which is usually located on the control panel.
May 09, 2015 • Ovens
When I bake, my oven will start beeping and flash F2, what is that and how do I stop it?
Which manufacturer built your oven? The F2 error usually means that the oven temperature sensor is claiming the oven is too hot (or got too hot in the past). This usually requires replacing the temperature sensor. Sometimes, the control unit (clock) needs to be replaced.
I hope this helps. Please add a comment with the make and model of your oven for additional support.
Mar 18, 2013 • Ovens
Control panel flashes F7
The F7 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F7 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
When the electricity goes out the F7 button comes on and the manuel says to turn the power to the unit of and it still comes back on
Unfortunately the F7 error code normally means a problem in the controller or touchpad (replacing both is common and parts alone is about $300)
You might try shutting down the power. Then finding the ribbon cable connector for the touch panel, unplug and clean the edge connector with a #2 pencil eraser. Sometimes that improves the signal enough that it will work a little longer, sometimes it doesn't and then you are talking about a $300 parts expense plus your labor or the $300 parts and Service call and labor expenses if you call a service tech.
When i turn the oven on it says "off" how can i get it to turn on
Hello- If you turn the oven off at the breaker, it should be a double 40 or 50 Amp breaker. And MAKE SURE both of the switches are off completely, there should be no display. Open the oven door and remove the black panel that is right under the control panel, where the top of the door would close on to. There are about 8 screws I believe. Once the panel is off you should see a thermostat right in the center of the cavity that you exposed about 4 inches back. It will have 2 wires coming out of it. The thermostat is about an inch in diameter and has a little red button in the center, facing up. If you can fit your hand in there press on the button and if it (the resettable thermostat) has been tripped it will make a little click. If you are concerned about having you had next to the wires even though the oven is off you can use a plastic pen to try to press the button down. Replace the cover plate and reset the breaker. If the thermostat got tripped the oven should work now. If it didn't and the oven still does not work then you may have a bigger and more expensive issue and may need a new relay board or possibly the EOC (oven control). Unfortunately these parts are very expensive and you will also need a Tech out to determine which one is faulty, there is some specific testing that has to be done on the boards themselves while the oven is live. I have seen this problem before and sometimes it is the relay board and sometimes the EOC. Hope this helps, best regards.
2answers
What does the "F24" message mean when it flashes on the oven readout?
hello,
simple ,The "F 24 " error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature or liquid substance
what you need to do to fix up your oven is to check on the wiring connection from the power supply to the panel indicator (control button ).
thank you and thanks for using fixya.
4helpful
Need to clean liquid drip from inside of door whirlpool built-in
Hi, The screws in the bottom edge of the door will need to be removed. The dor handles screws usually help hold the upper part of the door together. There might be screws on each side. Makes sure the door is laying on a flat surface and be gentle with the glass pieces. They are very fragile.
I am sending you a picture of the door pieces and how they line up inside the frame.
Please let me know if I can assist you further.
Vic
2helpful
Clean between door window panels
Sorry this is the only way to clean in there but if you take the door completely off and set it on a drop cloth Then take it apart it makes it a little easier
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
