Question about Sylvania SSC719C 19 in. TV/VCR/DVD Combo
How to change channels without remote
I own #ssc719c; but diont haave a remote control for it-can you help me with that?
1 Related Answer
Anonymous
  • 132 Answers
SOURCE: I have a Sylvania SSC719C with no remote, have
You will have to get into the menu to be able to switch it on/off. You may be able to do it by using the buttons on the tv. If not, you will need to try to find an original remote for that tv. You can normally find one by searching google or even ebay.
Posted on Jul 29, 2010
Testimonial: "Thank you very much! I'll look on ebay."
How to change the channel on a pANASONIC pvdf 2704 without a remote?
Without remote control, there is no option to change channels.
Aug 18, 2013 | Televison & Video
I have a Sylvania SSC719C with no remote, have programmed my DTV remote to control on/off and volume but I need close captioning on tv, do I need another remote for that?
Jul 29, 2010 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
I have a philips pm335 universal remote control
I went to the Phillips website and I wasn't able to find a code list. However, I did find the instructions to program your remote with "code search". Basically, it might take some time, but you can program your remote without the code list.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 26, 2008 | Philips Universal PH301S Remote Control
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Please help
It depends on brand. For Philips, press mute button to save code. The best website I found for all brands of remote codes and instructions is http://www.remotecodelist.com/remotes/
Apr 25, 2008 | Philips Magnavox Learning Universal Remote
Remote code
Hope this helps :)
Apr 15, 2008 | Philips Universal PH301S Remote Control
REMOTE CONTRPL CODE FOR SYLVANIA TV
what is your model # for that television?
I just went thur the same situation on a Model # SSC719C
Let me know.. GURU Jay
Feb 19, 2008 | Televison & Video
Sylvania tv model # ssc719c
I had the same problem programming my directv remote to recognize the ssc719c. What finally worked was programming AV1 (not 'TV') with the sylvania DVD code 20821. This allowed me to turn the tv on and off and change tv channels, but wouldn't allow me to mute or change the volume. To fix this, (at least in my case) you have to program your remote to recognize the volume and mute buttons in the AV1 slide setting. I assume other (non directv) remotes similarly disable the volume and mute buttons when the remote is not in satellite or tv mode. Anyway, here are the instructions that activated the volume & mute buttons on my remote: "Depending on how you set up your remote, the VOL and
MUTE may control the volume only on your TV, regardless
of the position of the MODE switch. This remote can be set
up so that the VOL and MUTE keys work only with the
component selected by the MODE switch. To enable this
feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys.
2. Using the number keys, enter 9-9-3. (The green light
will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light
flashes 4 times.)
Now the VOL and MUTE keys will work only for the
component selected by the MODE switch position."
To sum up: if you find a code for your remote that will turn your tv on and off, but doesn't seem to do much of anything else, it's probably the right code; your remote is probably set up not to recognize volume or mute inputs in AV1 or AV2. You change that using a remote-specific code that's probably found somewhere on the remote maker's website.
Jan 31, 2008 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
SYLVANIA SRCD227 REMOTE CODE
First tell me what brand tv and date of mfg & model# maybe I can help. Chuck [email protected]
Sep 20, 2007 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Televison & Video Logo
16 people viewed this question
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
