Please help any suggestions appreciated
A few of these (not sure if this model) have two mirrors inside--stupid idea and only a few had that--.
If this is the case here--little mirror (I mean LITTLE) is at bottom pointing up from the optical lens--gets dust and such from the fans= picture gets darker to the point where brightness is very diminished.
Mitsubishi can tell you if it has two mirrors (the large one in rear of set must not be touched and never needs cleaning as any finger prints etc will show in the picture.
If two mirrors I can tell you what to do--15 minute two person job.
SOURCE: Mitsubishi WD-62525 DLP has no picture
Here's something that might also be useful. After you turn on
the set, and get the regular red blinky lights, hold down the Device
and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
SOURCE: Mitsubishi Projection TV WD-62525
I RECENTLY HAD A LAMP ISSUE THAT MAY ASSIST. I HAVE A MITSUBISHI WD-52525 52" DLP. I HAVE OWNED THE UNIT JUST OVE THREE YEARS. THE UNIT INDICATED THAT THE LAMP NEEDED TO BE REPLACED WHEN THE UNIT WAS TURNED ON. I ORDERED A LAMP AND BEFORE IT CAME IN THE UNIT QUIT WORKING. I REPLACED THE LAMP AND WHEN I POWERED UP THE UNIT I GOT A STEADY YELLOW INDICATION AND THEN A SOLID RED. MITSUBISHI TECH ADVICE STATED THAT I MAY HAVE BEEN SHIPPED A BAD REPLACEMENT LAMP. I SENT THE LAMP BACK AND ANOTHER WAS SENT TO ME. THAT LAMP ALSO GAVE THE SAME RESULTS. I CALLED CHUCKS ELECTRONIC REPAIR AND A VERY KNOWLEDGABLE TECHNICIAN RESPONDED TO MY HOME. IT WAS DISCOVERED THAT THE POWER SUPPLY BOARD WAS BAD AND THAT THE LAMP NEVER NEEDED TO BE REPLACED. I SPOKE WITH REPRESENTATIVES AT MITSUBISHI SEVERAL TIMES AND THIS WAS NEVER EXPLAINED TO BE A POSSIBITLY. THE TECHS AT MITUSBISHI BASICALLY JUST READ FROM THE OWNER MANUEL AND HAD NO IDEA WHAT THEY WERE DOING.
SOURCE: How to replace Bad Capacitors on a Mitsubishi WD-62525?
#1 press menu on mitsubishi remote control.If the white round cloud don't go.
you need to replaced block optical......light engine
SOURCE: wd 52525 52 in dlp tv screen needs cleaned
all you have to do is, take the 12 screws out from around the screen, from the back, there are also like 4 of them on the front, but usually , you can just lean the screen out far enough to use a swifer sweeper in there, and the dust isnt going to be on the back of the screen, it will be on the projecter, do the screen while the tv is on, then you will realy see the dust on the projecter
SOURCE: Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
