Question about Sherwood RX-5502 Receiver
Have you tried makeing sure that the latches, if any, are released or checking if there is something blocking the place where you insert them?
Posted on Apr 03, 2012
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
May 28, 2015 | Onkyo TXSR309 5.1 Channel Home Theater...
Feb 25, 2011 | Audio Players & Recorders
Nov 11, 2010 | Denon DRA-685 Receiver
Sep 19, 2010 | Harman Kardon AVR 120 Receiver
Jun 15, 2010 | Insignia 200W Stereo Receiver
May 31, 2010 | Pioneer VSX-515 Receiver
Jan 15, 2010 | Audio Players & Recorders
Oct 11, 2009 | Teac AG-370 Receiver
Apr 13, 2009 | Dual XDMR-7700 CD Player
May 22, 2014 | Sherwood RX-5502 Receiver
Nov 30, 2012 | Sherwood RX-5502 Receiver
51 people viewed this question
