Question about Bunn CWTF 15-APS Coffee Maker
Connect water line to bunn cwtf 35
What fittings or tubing do I need to connect the water supply to the coffee maker?
Posted by Bob Brown on
5 Related Answers
Kelley Hopper
  • 67 Answers
SOURCE: my bunn coffee maker CWTF-15 21604-0001
It sound like you are either missing the sprayhead or the temperature isn't hot enough. Check first to see if the sprayhead is there. It fits under the brew basket and looks like a little shower head - it's round and has usually five or six little holes in it. If it is missing your coffee will be weak due to the water not being spread across all of the grounds evenly.
The other thing to check is the temperature. Depending upon where you live the water should be between 185F - 200F. If the water is below that temperature the coffee may look like tea.
Posted on Feb 01, 2008
Steve
  • 3289 Answers
SOURCE: bunn omatic model F20 doesn't stop dripping
Check out:
http://whles.com/General%20Mtx%20Knowledge%20%20Tony%20Roach/BunnOMatic%20F35%20F20%20F15%20x.pdf
This is the free full service manual F15, F20 & F35 complete with troubleshooting section at the rear. This section has easy, plain english steps to follow to solve this very problem (others, too).
Posted on Dec 02, 2008
Anonymous
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
Posted on Dec 11, 2008
Gord Thurston
  • 131 Answers
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
Posted on Feb 10, 2009
atbsmmom
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
Water is not hot when turn on
check the heat switch in the rear. if it's on, check the thermal fuse in the top right rear of the brewer. it'll be in a now browned tubing. you can get it through bunn (800) 352-BUNN (2866)
Jan 05, 2014 | Bunn CWTF 15-APS Coffee Maker
Water not coming out of hot water spigot
thermal fuse is blown. it is located in the top, right rear of the machine in what is now browned tubing. you can either bypass the fuse with a jumper, or get a new part through bunn (800) 352-BUNN (2866)
Dec 10, 2013 | Bunn CWTF 15-APS Coffee Maker
I need to ship a 3 burner BUNN CWTF 15-3. How do I drain the water out?
You can take the lid off and unscrew the nut that holds the water tray. Then take a 3/8 hose to siphon the water out of the machine.
Apr 17, 2013 | Bunn CWTF 15-3 Coffee Maker
Bunn coffee maker heating element wont turn off
Apr 13, 2013 | Bunn CWTF 15-3 Coffee Maker
Hi. how to connect water line from main to machine?
In the back of the machine is a copper (1/4" flare) fitting, From main water line you might have 3/8" comp or 1/4" comp fitting.
Find out the size of the fitting and if you have to get a flare to compression adapter for the fitting in the back of the brewer and the water line
Let me know if you need more help.
Note: If this going to be installed at a business you need to install a check/one way valve in the water line.
Jan 12, 2011 | Bunn CWTF 15-2 (1 Top Warmer) Coffee Maker
Cwtf is a contant dripping from the dispenser funnel, how do i fix this?
Inlet valve is leaking.Valve is located by removing front access panel.Can be rebuilt using p.n. 1111.0002 repair kit.You can verify by removing top lid and finding water leaking at fill basin tube.
Dec 27, 2010 | Bunn CWTF 15-APS Coffee Maker
Wiring
jumper the red and white wires at the terminal block
Feb 14, 2007 | Bunn CWTF 35-APS Coffee Maker
Bunn CWTF 15-APS Coffee Maker Logo
109 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
