Samsung s730 camera says memory full after 6 pictures have been taken..and I dont even have memory card in? I dont have the instruc tion manual camera was given to me without it!
SOURCE: Camera says "memory full," but there's no pictures...
I had this problem, I don't know how it happened. I have the samsung digimax s500, this is what I did. 1 press menu 2 go to 'setup' 3 scroll down to 'format' 4 click right and scroll down to 'yes' that fixed mine, good luck
SOURCE: camera says my memory is full
It can only take a 2gb memory card. anything higher than that it won't be able to use. The reason it's saying the memory is full is because it's still using the built in 15mb (something like that)
SOURCE: Card Locked Samsung SL 102 Camera
there is a lock button on the memory card check it if it is SD card or camera might not support the card try 1gb card
SOURCE: Camera says memory full, even thou I have put in a
With the card out of the camera, go into the menu and find "format"...follow the on-screen instructions. Then, insert the card and do the same thing.
SOURCE: I put a new memory card in the camera and it says
You need to eliminate the pics from the internal memory. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the "format" thing again for the card. Everything should be normal now.
