Question about Korg Pa50 Professional Arranger Keyboard with SD Card Slot
FACTORY RESET ON KORG pa50SD
On the lower or higher Program/Performance.. non of the sounds ie Organ, Bass. Synths, etc are in the right place? For instance if I use the lower and select BASS its says EMPTY !! If I select the upper and go to GUITAR its displays Organ sounds... Surely I should be able to select a "sound/voice" and simply play the keyboard with that sound?? I can with my old faithful M1
Posted by Andy James on
Andrew
    New Friend:
I use korgpa50sd i had some voices by default but once when i inserted my sd card into the arranger every voices got deleted and now everything is new...so can you please help me to get back the old voices?
Posted on Jul 09, 2013
petre
    New Friend:
*** resetez orga pa 50 ca numi mai tot pachetul
Posted on Nov 06, 2012
5 Related Answers
Michial Gueffroy
  • 1140 Answers
SOURCE: when I play the sound come out distorted, like it
The manual is at:http://www.korguksupport.co.uk/upload/X50_OpGuide_E1.pdf if you don't have one. Try saving everything you want to save first if you know how to do that. Then initialize the keyboard. Follow the instructions on page 111 carefully. It sounds like you created an undesirable effect and accidently assigned the Pitch Bend Lock function to the effect. This parameter is explained on page 41 under Pitch Wheel Mod Wheel. Hope this helps.
Posted on Aug 20, 2009
Fred Yearian
  • 5603 Answers
SOURCE: KORG SP-250. Keyboard powers
There is probably a cable loose that connects the keyboard itself to the processor... OR the key contacts have been contaminated by spilled liquid. The keys are scanned as a matrix. The contacts will be a conductive rubber pressed against circuit board traces. Clean contact "pills" and the circuit traces with ONLY 99% isoprophyl alcohol.
This is NOT for the unskilled to attempt a DIY other than carefully opening and looking for a cable that has come loose.
Posted on Mar 22, 2011
Andrew Conroy
  • 298 Answers
SOURCE: i have a korg n5 music workstation. one side of my
It could be that you have a keyboard 'split' turned on but haven't allocated a voice / sound to one half of the keyboard.
See chapter 1 page 11 and chapter 3 page 27 of the manual available at the link below for a more detailed explanation
http://soundprogramming.net/manuals/Korg_N1_N5_Manual.pdf
Posted on Feb 02, 2011
soundproman7
  • 29 Answers
SOURCE: I dont know how to replace the internal battery on a Korg M1
You should be able to remove the top cover off your keyboard and see the quarter-size battery mounted in a holder on one of the circuit boards.
I don't recall the exact location on this particular model, but once you've located it, all you have to do is slide it out from under the contact spring that holds it in place and slide a new one in.
You'll want to make the swap fairly quickly as some models can lose their memory settings if battery power is lost for a relatively short amount of time.
Posted on May 20, 2009
cosmin_bcr
Cosmin Becheru
SOURCE: Hi, I have korg
Korg pa 800 = poor quality product (I have the same problem) ,pa 2x it's better.
Posted on Oct 06, 2011
Why lower keys dont come on , on a kimball model 700-775
I think you are speaking of an organ.
Your organ has electronics inside it, and I believe the circuit board for the lower keys has a broken connection.
You should find an electronic organ repair place.
I just looked online and found several places.
Since you may be near to none of these, relay on your computer to find someone who can repair this circuit board.
They will have to tell you how to take it out of your unit.
God bless your efforts.
Feb 24, 2017 | Music
At times during a performance the organ sounds drops significantly compared to the ensemble sounds, what could be the problem?
Has it always done that? It could be it just doesn't have enough power to play organ at full volume along side the ensemble.
May 25, 2015 | Roland VR-700 V-Combo 76 Key Stage Piano
I just got this keyboard and want to hear the program # 110 Upright Bass 1 and its Ride Cymbal; I hear the bass, but not the cymbal. The sound is listed in Appendix B on B-14 in the manual. Thanks!
Verify the sound in headphones directly from the unit. The cymbal MAY be panned to one side or the other and will require higher frequency response than some of the piano notes.
Sep 20, 2011 | Kurzweil SP3X 88-Key Stage Piano
How to perform a factory reset?
1. Power-off the PS60.
2. While holding down the four PERFORMANCE buttons and the OCTAVE DOWN button, power- on the PS60. The PS60 will be initialized, and the factory-set data will be written into internal memory. The display will indicate "Initializing..." while data is being written. Never turn off the power while this indication is shown.
Manual available here:
http://www.korg.co.uk/downloads/ps60/docs/PS60_OM_E1.pdf
Jun 24, 2011 | Korg PS60 61 Portable Performance...
I recently broke the E string on my Ibanez 5 string bass and replaced it with a 100 guage one. The sound level is now very low, lower than both adjacent strings. I have tried lowering the bridge, but this ...
Replace it with the same size as the original and the original type. The 100 sounds right for the E. Make sure it is the SAME type string as there are non magnetic for some guitars and if you have magnetic pickups the bronze types won't work. There are also round wound, flat wound and some are flattened on one side. You need to make sure the replacement is exact type. Take sample of old to show store clerk.
May 24, 2011 | Ibanez Srx505 5 String Srx Bass
I have a technics sx ex35 organ with a broken floppy diskdrive. Where can I purchase a new drive and how much will it cost me?
It is near impossible to get parts for some of the Technics things... Find a source dealling in scrap computer recycling... take your drive there and see if you can find some that will fit connection wise and mechanically and just try them...
IF your floppy is one of the old 720K drives, those are almost non-existent... You can tell if you use floppies disk that have two holes at the two corners instead of a single one those will use the 1.4Mb conventional rather than those 720K ones...
SOMETIMES you may have to jumper configuration pins to work with these synths...
Nov 15, 2010 | Music
In juno di faviourite button when i bush one after another there is sound gap in tones ie fraction of second gap
This is probably normal. The sound generators need to re-configure when changing voices. This means that while one set is generating the old voice, others have to be set to the new and the old cancelled. The sound has to be muted between the setting changes... this takes a fraction of a second to do in the hardware. The only solution is to use two synths and have each set to the sounds you want. MANY musicians rack up two synths just for this purpose.
Oct 15, 2010 | Roland Juno-D
I have an older model lowrey spinet organ - very similar to the Jamboree model M325 but with a few significant differences. Only 6 rhythms instead of 18. No metronome. Has AOC,Genie plus organ,Genie bass,...
Try this link:http://www.organservice.com/ Here's another one:http://www.combo-organ.com/Schematics/index.htm Join this one for free and post:http://organforum.com/forums/thread/73735.aspx This site is good too:http://www.combo-organ.com/spares_and_repairs.htm#Electrolytics Hope these help.
Jan 09, 2010 | Boss Micro BR Digital Recorder
Looking for a schematic of the Casio ctk-700 to
The keyboard is LIKELY scanned as a matrix.
You have two problems:
The contacts in the Thomas will have to be totally disconnected rendering use of any of the Thomas organ unlikely.
The second problem is that the keyboard LIKELY has velocity sensing. This means TWO contacts must be used PER note. One contact "makes" first and "breaks" last. This is used for velocity sensing on synths. The Thomas foot pedals likely only have a single contact per pedal, and even if they had two, it is unlikely they sequentially close..
The matrix scanning is accomplished by sensing the connection of two crossing points on a matrix of circuit lines. USUALLY each of 12 wires tie to all of one note across the board. Then two other lines for each octave "strobe" the first make contact and then the second of those strobes the second make contact. There are two of these strobe lines for EACH octave on the board.
Remember that these lines scan at digital logic speeds so wire length and NOISE/STAIC DISCHGARGE PROTECTION is a must.
Aug 22, 2009 | Casio Music
Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Aug 07, 2008 | Korg Mini Kp Kaoss Pad
Korg Pa50 Professional Arranger Keyboard with SD Card Slot Logo
3,752 people viewed this question
Top Korg Music Experts
Poul Brinchs Larsen
Becketts Music Ltd
Becketts Music Ltd
Are you a Korg Music Expert? Answer questions, earn points and help others
