How do I replace pull rope which broke? Do you have instructions for thiis problem?
SOURCE: Need to obtain a new belt and pull rope for my Tiller
you can get a pull rope at wal-mart.measure the belt and any parts store or place that sells lawnmower belts should have one.if the rope broke close to the end knot just pull the end knot with some needle nose pliers.once you have all the old rope out lay the old rope pieces on the ground and cut the new rope to match it as far as length.turn the pulley that the pull rope goes in six turns counerclockwise.then turn the slot the knot was in to the hole the pullrope goes thru and fish it thru then pull it up and out with apaiar of needlnose have someone hold the pulley until you tie a small knot in the end of the pullrope the hold the pullrope and let it pull it in.you might have to cut some off at the handle if its still too long.to do this pull some rope out and tie a quick knot so the rope can't slip back if you let it go.
SOURCE: the pull rope to start
You need to pretension the spring before installing. Easier to do this before attaching the line, but there is a technique (at least for larger engines) for adjusting spring tension with the line still on. If you need I can describe it for you or tell you where on youtube I saw a guy do this. That video was for a snowblower engine, but the technique worked on my chipper. I see no reason why it would not work on a smaller two stroke, assuming there is nothing wacky about the configuration. I would think that a recoil starter for a two stroke and a four stroke should all use the same principle,.
