Question about Ariston Technologies Washing Machines
Door error in display of ARM7F125 Ariston washing machine
I have an Ariston ARM7F125 washing/dryer machine. In the display appear "door". The led of door loocked light only one second and then remains off all time. I change the interlock door mechanism for a new one but the problem continues. Then I sent to repair the main pcb but continue the same problem. I need to know if this fault is relationed with another thing for ex. presostat, etc. I would appreciate your suggestions. Thanks in advance.
Posted by raul f. borjas on
1 Related Answer
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: Problem with Neff washer/dryer V534OXOGB. When
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Posted on Aug 28, 2011
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
After you determine which the alarm code appeared we will able specifically to help you.
Dado
Sep 13, 2014 | Ariston Technologies Ariston AWD12 Front...
HOW TO FIX O9 ERROR CODE?
F09: Machine Setup Error Found (AWD12)
Setup error or incompatible EEPROM
Control Microprocessor Version
Ask for EEPROM Spare Part indicating Microprocessor version
Reflash EEPROM
Check electronic controller
Dado
Sep 09, 2014 | Ariston Technologies Ariston AWD12 Front...
Ariston h20 errors
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jan 14, 2014 | Ariston Technologies AWD 129 NA Washer/...
Ariston AQXXF 129 Error code F 05 - What is this?
see this causes and fix it. God bless you
F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.
Sep 30, 2012 | Ariston Technologies Washing Machines
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
Cannot open Wash door
Here is a tip that I wrote about how to get your washing machine door opened...
Washing Machine Door Jammed
heatman101
Jan 24, 2011 | Ariston Technologies Ariston AWD12 Front...
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
ARISTON WASHING MACHINE DOOR PROBLEM SO ON/OFF BUTTON DOESNT WORK
Well it depends on how old your machine is, if eveything else is fine then replace it. The cost will vary depending where you buy your part from. It could cost but worth it if machine is reliable. try
www.lpdlpd.co.uk
Aug 09, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
1,869 people viewed this question
Top Ariston Technologies Washing Machines Experts
Marvin
Marvin
Harrie
ray gallant
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
