I am unable to use my tv at present, it appears to be linked to the hdd, the input 1 sign appears on screen and immediately goes off again, I believe it is not receiving the signal, dvd is fine. Cannot operate the menu button on hdd, will not allow me to do anything to it, have unplugged etc, it has happend before but do not recall how I fixed it, many thanks for any clues, any sure it is simple. Yvonne
SOURCE: LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
SOURCE: Toshiba 57H82 Blurry Pic on HD inputs except Xbox 360
Probably your G-Hyper board. You will need expert servicer and should cost about 3-400.00
Craig
www.classtorations.com
SOURCE: USDTV (Hisense) DB-2010 HD Receiver failed after 1 month.
no color in picture.can someone help.
SOURCE: Panasonic DVD Recorder - Digital tuner stopped working
Is your recorder hooked up to the new convert box for digital antenna reception?
I am currently researching the convert boxes for my dvd recorder. I found that some dvd recorders already have digital converter boxes already installed. This might be the case for you.
