This is pulled from the tutorial PDF:
DESIGNING YOUR MENU
Now that your content is added, you can customize the look and feel of your menu. You can change the background, title, and chapter button layout and text. Before changing your text, it's recommended that you set your background first. Often, the color of your text will be dependent on the background color. A good amount of contrast between the colors is necessary to ensure that the text stands out clearly
The option to change the background is in the Themes tab.
check the gold contacts on the back of the face and the unit also check the release mechanism theres a little black button (not the reset) that when face is pressed up against it it activates power to the gold contacts thus powering the buttons
When you first open a picture file (particularly an image file you got from the web) it might be locked. Check on the Layers palette to see if you see a padlock symbol like this: If the file is locked it is because it is in "Index color mode" and you need to change it to RGB. On the menu bar, go to Image > Mode > RGB. Your image will still be locked, however, now you can use the Layers palette again to make a duplicate of your image. Click, drag and drop your "Background" layer to the Create New Layer button, like this: Now you will have two layers: Background (Locked) and Background Copy (not locked). You can drag and drop the locked layer to the trash can if you want to (you don't need it anymore). You should now be able to edit the new Background Copy layer freely.
Check the white balance setting of the camera. As you have a yellow cast, it could be because you are using it in Fluorescent (or Tubelight) setting. Changing this to Auto should solve this problem.
what you have to do is push and hold, i believe, the air/heat dry button for 5 seconds and that should change the control from lock to unlocked. look for a "lock" symbol under the button and thats the one that you have to hold in on. it may not be the air dry button but there will be one that does have the symbol.
if you have a universal remote ( i just used the all for one 4 model )
1 ) press the vcr button. 2 ) hold the magic button down wait for 2 red flashes. 3 ) enter code 0240. 4 ) press the power button on the remote tv will turn itself off. this will get the panel lock off the tv.
i have just done this after 30 mins of trying to work out why the panel lock would not come off with trying the tv codes. you have to use the vcr codes. my tv is now working and my grandson can play his playstation again with no problems just had it working.
dated 13:07:2010 1800pm. hope this helps someone
