Baby Gear Logo
Posted on Apr 02, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The zip on my seat has broken, can I get it repaired or do I need a new seat cover?
The top left hand zip has broken, could I get it repaired? And how long will this take as I need it ASAP.
Dorel UK
Level 3:
  • Quinny Master 1,637 Answers
  • Posted on Apr 15, 2013
Dorel UK
Quinny Master
Level 3:
Answers
1637
Questions
0
Helped
454157
Points
2410
Hi
We don't repair zips on products it would be a case of a replacement.
Suzuki 125 marauder removing seat
Brake the lock and then you need to buy a new one
2006 ford explorer headrest latch needs repairing
In order to repair this you must have the seat back cover removed, since you really don't know what is broken inside and it is a safety issue I would have the dealer repair this.
Broken trim on driver seat 2010 navigator
I used zip ties to tighten it back down on my 2006 navigator. Sounds like same flaw in manufacturing covers many year models. The zip ties( large ones) helped for a long time but I'm still looking for better longer term fix myself.
3helpful
Can't close doc cover properly - seems 'broken' at hinge - can I fix this myself?
The left hinge breaks often enough that Brother changed the part number of the part. I hope that means the new part is stronger; I haven't seen one come back for a second repair. Assuming it's the larger, left hinge that's broken (It always is.), you need an LP2403001 HINGE ASSY L. You can find it from a servicing dealer or online, and it's easy to replace.
Look at the back of the machine and find two large phillips screws in holes. They keep the hinge blocks from coming up all the way out of the machine. Remove both of them and lift the top cover up until it's connected only by its cable. It might take a helper to hold the cover, but you need to unscrew the hinge assy. from the top. The three screws are obvious and easy to reach now that the cover is loose. Put the new hinge on, lower the top back down so the hinges drop into their holes, and put those screws back into the holes in back. You're done.
1helpful
Broken belt on a Model #U4655-930 How do you get to the engine pully We removed to brush mechanism
This model you will need to remove the bottom plate first and the top cover next. the cover can be gently pryed off with a screwdriver left and right sides from the back to the front. first put the new belt on the roller and then put roller on vac insert new belt thru hole and pull onto the motor shaft. move roller by hand to center on pulley. and then replace hood and screws
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 12, 2009 • Vacuums
1helpful
How do you remove the seat, how to top up the oil,
left hand pannier lever lift it as if you was to remove the pannier you will see a smal lever in there then the seat will lift the seat is in to parts.the oil cap is on the right hand cam cover pull off the silver cover it just pulls off to the left watch when you do not to pull off the plug cap.check the level with the bike upright and top up 1/4 of a litre max at a time then run the engine let it sit for a min then recheck
The zip handle has broken off. Where can I get it
you will need a new seat cover contact www.buggypitstop.co.uk they should be able tro help you.
2answers
I am unable to locate the fuse box on my 1984 FJ600, can anyone help me out??
most yamaha bikes have fuse box mounted behind left hand sidecover beside sarter relay or under the seat behind the battery
17helpful
One of the softclose buffers on the Subway toilet seat has pulled
Each soft close 'Barrel' is handed - one left - one right. (One is grey - the other white).
Most soft close errors occur because the seat hinges come loose. When this happen, the barrels slightly pull-out of the seat. (There are silver discs on the barrels - These should be tight against the seat).
Once the barrels become loose the first thing that happens is the top cover won't soft close - but the seat still does.
To rectify - puch both barrels tighly into fitting and tighten the hinges. (See below).
To tighen the seat hinges you need to get a flat headed screwdriver underneath the chrome round hinge cover - and 'flick off'. Underneath is a X head screw which id also hexagonal. You can either tighen both by spanner - or screw driver. (sometimes these can be tricky - but it will come off).
If both cover AND seat do not soft close AND the barrel silver discs are firmly located against the seat - the barrel has probably broken.
If so - spare parts can be obtained here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
9helpful
2002 saturn sl1 pcv valve
The PVC valve is located in the valve cover (top "cover" of the engine, near the oil filler cap) On DOHCs, it is immediatly to the right. On SOHCs, it a few inches to the left.The PVC valve is held to the valve cover with a rubber grommet type seat.
1. Remove the hose that connectes the throttle body unit to the PVC valve.
2. Using your hands, remove the PVC valve from the rubber seat. Wiggle it back and forth, then pull it straight out.
3. You can either clean this with carb cleaner, or simply replace it with a new one (<$5 at most auto stores)
4. Put the PVC valve back into the rubber seat and replace the hose
Top Quinny Baby Gear Experts
Jennifer Rock
Jennifer Rock
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
