Question about Samsung ES30 Digital Camera
My Samsung 5x ES30 Zoom Did Not Operate Normaly
My Samsung 5x ES30 Says " The zoom did not operate Normally. Insert the battery again and turn the Camera ON." I tried to insert the battery again but the camera won't work. Can anyone help me with this??
Posted by jhapui on
  • Anonymous Mar 26, 2014
    zoom did did not operate normally. insert battery and battery af=gaing and turn the camera on.
Ray Boettger
    New Friend:
I tried the paper shim going around between two lenses and body and lens, compressed air, allowing small amount of alcohol on q-tip on gap - and nothing would get my lens to open. Then I held in flat between my two hands and "gently" gave it a very light twisting diagonally, once in each direction. Hit the power button and it works fine now. As my gaffer used to say, "Don't force it! Get a bigger hammer!"
Posted on Nov 06, 2015
lisacoleiams
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
Ensure you're using new batteries and try again.
Posted on Apr 02, 2012
1 Related Answer
Ty Price
  • 11967 Answers
SOURCE: I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Posted on Aug 20, 2011
Why my samsung camera es75 zoom did not operate normaly after open & insert the battery again? Plz answer me.
If you removed the battery while the camera was on this spells trouble,
Jan 24, 2013 | Cameras
The zoom is not working properly
And it wont. it needs serviced,
Dec 05, 2012 | Samsung PL Cameras
My samsung st66 camera was dropped and it say the zoom did not operate normally zoom wont operate normally
When I turn on the camera it says "The zoom did not operate normally, insert the battery again and turn the camera on..."
i reset my cammera but problem still please guide me
Nov 10, 2012 | Samsung Pl20 - 14.2 Megapixel, 5x Optical...
My samsung pl20 camera was dropped and it say the zoom did not operate normally
Pull gently back and forth on the lens while in outward position. Do this several times until you hear a click. This will put the lens back in place and should go in and out afterwards with no problems.The lens was knocked out of alignment when dropped and do the above will put it back into alignment.
Jun 21, 2012 | Samsung Pl20 - 14.2 Megapixel, 5x Optical...
Samsung ST90 help
Return to seller as faulty goods
Aug 22, 2017 | Samsung ST90 Digital Camera
The zoom did not operate normally insert the battery again and turn the camera on. if the camera does not op normally do not put excessive pressure on it and contact the service center i got this error...
The solution is very simple.
you are going to remove the battery (while this screen is on) as the command screen tells.
And your camera should function properly.
I tried it and it worked.
NB; Do not try to close your camera then remove the battery.
Remove it while the camera is still on.
Jun 04, 2011 | Samsung ES30 Digital Camera
Zoom did not operate normally,insert the battery again and turn camera on again Camera doesn't operate normally
Hi had this problem with my WB100. Zoom would come out then pop back in and say zoom nit not operate normally, please put new batteries in and try again or contact bla bla. What i did when the zoom popped out is i held onto it and didnt let it retract back and turned it back on. It worked after that so i guess the zoom must of been a little forced in when it was in use last in when turned on it wasnt fully going forward. Worked for me so worth a shot
May 27, 2011 | Samsung PL120 Digital Camera
Samsung ES30 Digital Camera Logo
699 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
