Question about OKI C Office Equipment & Supplies
SOURCE: Canon MX310 Printer - How to reset to factory settings?
usually there is a menu in the printer itself. does it have its own little screen? if so go to tools or setup n look around to find default or reset n hit ok.....lemme know what happens
Posted on Sep 30, 2008
SOURCE: Printer stuck in copy mode--can I reset the printer? Have tried everything.
Hi
Try to turn it off and unplug it for a few minutes, turn it back on and leave it to copy mode. try printing from the computer then/ keep us posted.
Thanks
Posted on Nov 14, 2008
SOURCE: How to reset to factory default Dell 1720 network printer
1. Turn off the printer
2. Open the front cover.
3. While the Continue and Cancel buttons are depressed, turn the printer on.
4. When the error LED on the control panel is lit solid, close the cover.
Posted on Aug 28, 2009
SOURCE: How do I reset my drum life once I have inserted a...
Open front cover; hit CLEAR button; hit PLUS (up) button. Close cover. Done.
Posted on Aug 31, 2010
SOURCE: I have an Oki c9650
Hi.
Default password is six zeros (000000). If that does not work, then the password had been changed.
Here correct reset procedure, this will reset DRUM, FUSER and BELT:
1) Turn ON printer and keep holding "+(up)" & "-(down)" and "help" buttons
2)Keep holding and wait until "OKIUSER" message appears
3) Press + or - button until you get "ENGINE DIAG MODE" on display
4) Press "ENTER", you get display showing: "DIAGNOSTIC MODE XX.XX.XX S-MODE"
5) Press + or - button until "NV-RAM INITIAL" is displayed
6) Press "ENTER"
7) Display will show "TABLE 1" message
8) Press "ENTER" until you get "EXECUTING RESET"
9) "NV-RAM INITIAL" message will flash on display
10) Turn OFF the printer, wait 10 sec, and turn ON again
Regards.
Posted on Oct 19, 2010
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
• No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Sep 22, 2011 | HP Color LaserJet 8550dn Printer
Jun 10, 2010 | Konica Minolta PagePro 1350W Laser Printer
Mar 13, 2010 | Brother HL 1440 Laser Printer
Nov 11, 2009 | OKI C6100dtn Led Printer
Nov 10, 2009 | Brother HL 5250DN Laser Printer
Jun 07, 2009 | Dell 944 All-In-One InkJet Printer
May 15, 2009 | Brother HL 5250DN Laser Printer
Nov 16, 2007 | Dell 3000cn Laser Printer
87 people viewed this question
