Question about Music
Keyboard stand by casio seems to have no support to hold the keyboard. The keyboard slides from side to side on the stand
Posted by debbie mckinney on
Raymond Kellogg
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
If you have your keyboard mounted on a stand and you notice that it keeps on swinging from side to side, then that means there's an issue with the stability of the instrument and its placement on the stand.
With the many keyboard stands to choose from, it's so easy to just pick one that looks great or one that seems just the right size, but without looking at the specific dimensions of your keyboard, it's possible to overlook important details and not get the right stand for it.
The key to selecting the best keyboard stand is to measure the dimensions of your keyboard. You should also check the structure and build of the keyboard and see if there are parts meant for mounting and placement on a stand. Knowing these things will help you find the most suited keyboard stand.
If the problem seems to be that the stand provides no support, it could be that the keyboard might have built-in fixtures and snaps that are compatible only to specific types of keyboard stands.
Find the best electronic keyboard stand with the help of Pick My Piano's reviews and guides by visiting https://pickmypiano.com/electronic-keyboard-stands/.
Posted on Dec 20, 2020
John McPherson
    Genius:
  • 1,212 Answers
Just add some adhesive Velcro (hook and loop fastener) The industrial rated for 25 pound should be good for most players, 75 pound rated minimum for Jerry Lee Lewis type players.
Set the stand at the height you want, put the hook tape on the stand leg top and then target the fuzzy strip to the piano. Be aware the pound rating is rated per square inch- so you will want to put a 10 or 12 inch strip of fuzzy on the piano, and 1 or 2 inch strips on the stand leg.
Posted on Apr 02, 2012
Got a used CTK 720 and it has no power. sugestions
try plugging in without the bateries...Also check your adaptor as well as your ac requirements on your keyboard..It specifically calls for a Casio AD-5 Adaptor.
  • 9V power supply; 850mA
  • Positive sleeve/negative tip This needs to match your adaptor Good Luck
http://support.casio.com/pdf/008/ctk_720_01_e.pdf
Feb 15, 2015 | Casio CTK-720 Electronic Keyboard with...
Computer does not have Ctk-720 driver
PC drivers available at Casio
http://support.casio.com/en/support/download.php?cid=008&pid=20
If you have a MAC google casio driver for Macs by 3rd party.
Jan 22, 2014 | Casio CTK-720 Electronic Keyboard with...
Can't connect my ctk-720 to my mac
The Mac needs the driver, and you may need to select it in Chooser as well. If it is not on the instruction disk, it should be downloadable from the manufacturers website.
Sep 25, 2012 | Casio CTK-720 Electronic Keyboard with...
Digital piano stand assembly cs-44p
Here is the manual for it http://casioelectronickeyboard.danielcadams.com/cs44-p-stand-cs44p-casio-electronic-keyboard-user-manual/
Jul 28, 2012 | Music
Need an owners manual for a Casio lk-100 keyboard
you nearest casio dealer may have one in the back of the store,
many buyers don't want/need the manuals so some stores hold on to them for such occassions
Jun 28, 2012 | Casio LK-100 Keyboard
My keyboard has 2 threaded holes in the bottom that look like they'd be used to attach it to a stand. So...how do I secure it so it doesn't fall off when my dog bumps the stand?
Unless the stand was specifically made for the Casio, the holes probably will not line up with anything. You can COUNT on them being Metric threaded and you have to be careful to not put too long screws in the holes. If you stand doen't line up with the holes, best to secure a piece of plywood to your stand first that is drilled to match the synth and attach the synth to the plywood. I don't know how your stand is made so I can't give you more details.
Jan 09, 2011 | Casio WK200 76Key Digital Keyboard
How do I attach an X frame stand to a casio electronic keyboard
Usually the keyboard sits on top of the X stand held by its own weight. Most of the smaller consumer keyboards do NOT have mounting holes for attaching stands. Piano keyboards that have 88 keys do usually have mounting holes as they are heavier. Most X stands have rubber ends on the tubes where the keyboard sets.
Dec 27, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
I need to know what driver i need to download and where for my casio ctk - 720 keyboard
The keyboard should stand alone and NOT require any driver. Drivers are for PC's,
Now if you are trying to connect the keyboard to a PC, then that is a different story. You did not mention that.
For tying a keyboard into a PC there are both USB and MIDI connections. You haven't mentioned using either.
When talking to a keyboard you will need music editing software, not a driver. That software you purchase SHOULD have what you need as part of it. There are also editors for the parameters in the keyboard. MOST of that software has to be purchased, although you sometimes can find shareware. Some can be quite expensive.
Oct 05, 2009 | Casio CTK810 61 Key Keyboard
Notes not holding
The key contacts need cleaned.
Aug 10, 2009 | Casio CTK810 61 Key Keyboard
Keys 7 and 8 from the bass side are lower than
In Casio Chord mode, the bottom keys up to the second F plays Bass Chords. The Keyboard is just putting the keys you play back into bass when you get up that high. If you read along the plastic edge above where they keys come out of the keyboard, it shows you where the Chord keys end and the Keyboard begins. If you want use of all the Octaves, slide the power switch to the first setting (normal).
Jul 14, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Music Logo
231 people viewed this question
Top Music Experts
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
