My PC software that drives the weather station has died and I can't find any help with Sharper Image. Any idea where I can download a good copy of the driver software so I can get the Weather Station running again? Thanks much - Shawn
Reguire driver/software for ec-ws115 wireless weather
Hi I haven't got found the software for the EC-WS115 yet. I did find a link to the site that Sharper image used to get the data:http://corporate.foreca.com/en/products-...
I went there and by giving them my name and email, I get weather for my town on a web page.
They email me the link...
I think I can get the software to work and would be happy to share instructions, if someone can post an ISO of the software CD.
If you have a Sharper Image ES-WS115 five day forecast weather station I believe have found a way to return it to service. I picked up a unit at a local thrift store that was still brand new in the box with only the owners manual missing.
The manual is available at
https:/www.manualslib.com/manual/783137/sharper-image-ec-ws115.html
Unfortunately the installer program on the CD only directs your web browser to a server that no longer exists to download the program to your PC.
After considerable searching the web I suspected the manufacturer of this product is NSHnordic.com. I found a similar product of their Ventus model W194 4-day forecast weather station. At this point I was willing to forego the fifth day if it would at least give any functionality. I downloaded their installer program for the W194 fromhttps://www.nshnordic.com/english/suppor...
This installer did download the program to my PC which easily installed.
I found that I needed to reboot for the program to load at this point.
If you do not see the user interface and after clicking the "4-Day Forecast" icon, get the message "This program is running on your computer", I start the Task Manager (Control/Alt/Delete), select the "Processes" tab, then select 4-Day Forecast.exe and then click the "End Process" button. Now when you start the program the user interface will display the first time you restart the program.
Once the program runs you should see the user interface and select the "HOME WEATHER" tab at the top then setting... button at the bottom. then click the "SET LOCATION" button make you selections then the "SAVE" button. Then select your preferences for Temperature, Wind speed, Time format, etc. Then click the "Save" button. At this point the program should display the current weather data. It's important you set-up the "Home Weather" as this is the data that will be sent by the transmitter to the main unit's display.
At this point I had trouble getting the weather data to transmit over to the display unit.
I wish I knew exactly what I did that finally worked but here are some of the things I tried.
1. Pressing the button on the bottom of the transmitter forces the unit to send data.
2. Disconnect the transmitter from the USB port, remove the batteries, wait a few seconds, reinstall the batteries, use a straightened paper clip the depress the reset button thru the small hole marked "R" visible with the battery cover removed near the "CE" molded on the bottom.
3. Uninstall and reinstall the program. This requires resetting your location and preferences info again and may require a reboot.
The data did slowly transferred to the display so give it a few minutes.
Happily, despite the software being designed for a 4-day forecast unit, I am getting all 5 days populated with all appropriate data.
Be persistent and good luck.
John
Please give me supco dataloger software
SOURCE: Is it possible to recommend me a on a weather
I can recommend you on Weatherlink Software but the market offers another good programs.'Weatherlink Software for Weather Stations' -Is a good weather monitoring, connect the Perception II, Weather Wizard III or Weather Monitor II to your personal computer. WeatherLink data logger stores data-even when your computer is not running-until it is transferred to your computer. You can use WeatherLink software to create graphs, calculate totals and averages, generate summaries, analyze trends, and more- all with your own weather database. Data may be exported to most popular databases.
SOURCE: need instructions for model #2316 La Cross
per the manual at http://www.lacrossetechnology.com/2316/manual.pdf on page 2 section 5 the unit sets its self to the world time radio signal from boulder colorodo on its own after it get the security code from the sensor pack.
SOURCE: I have a 00594 weather
hi.
I assume that you have used some fresh batteries,it is recommended to replace both indoor and outdoor unit to get a best result....after replacement you need to reset it..
I do not know if you have the instruction manual for your unit however just in case I hereby included a URL link for you to download it..
THIS LINK LINK WILL GIVE YOU THE USER MANUAL. ITS IN PDF FORMAT THIS WILL SURELY HELP YOU TO SET UP .
Take care and please Remember to rate/vote and give
me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://theguidedb.com/search/the-acurite-weather-stations-00594--wa-guide.html
SOURCE: manual for acurite ik634160 weather station
http://www.acu-rite.com/product-manuals.html
http://www.ehow.com/way_5552159_acurite-atomic-clock-setting-instructions.html
Please find what you want at the above links....
