My whirlpool double oven accubake GBD307PDS09 display went blank. If I press the buttons to put the oven on, they beep as if they are working and when I hit the start button it sounds as if the oven is starting, then after about 30 seconds it shuts off. I tried flipping the breaker but that didn't do anything. My wife previously ran a self clean cycle every other month and we learned the hard way and replaced the mother board about 4 years ago. We have not ever run a self clean cycle since. Any ideas? Any help is greatly appreciated.
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
SOURCE: My whirlpool double oven accubake GBD307PDS09
We have here a video showing how you can check the temperature sensor
We also here the parts diagram of your model
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
The display is now on with the error codes E6 and F2
I attempted to put the oven, the error codes cleared and the oven works fine now......at least for now.
And now I am back to square 1 where the display is blank. It seems to cycle and eventually the error codes will appear. And then it will be back in working order. And it will repeat again.
